combatentropy
From the PetaPixel link...
So if they've got this right . . .the new sensor can capture 88dB signal-to-noise ratio, which translates into approximately 14.6 stops of dynamic range in each direction or 29.2 stops EV. By comparison, the best sensor currently on the market (according to Adorama) is found in the Nikon D800E, and clocks in at only 46dB or approximately 7.7 stops in each direction or 15.3 stops EV
They haven't. In fact they managed to be wrong about two different things:
1. Dynamic range isn't the same thing as signal-to-noise ratio. Look at the spec sheet for image sensors, and each should be listed separately (for example, the CMV12000 has 60 dB of dynamic range and a signal-to-noise ratio of 41.3 dB; the IMX174 has 74 dB of dynamic range and a signal-to-noise ratio of 44.8 dB).
2. Neither has ever meant "in both directions." I really don't know where they got this.
Looking on the web I found a Sony White Paper on Dynamic Range that states that the best CMOS sensors have a dynamic range of only 60 dB
That white paper must be old. That would mean that the best CMOS sensors have a dynamic range of 10 stops (decibels divided by 6 equals f-stops).
