JimmyTheSaint
Carbonite Member
You're hard pressed to find someone to believe you and I actually lost data on the P2 card itself. There's the mentality here that P2 is sent from God, is Divine, and more infallible than the Pope. But, I know that I lost clips on the P2 card, not on the Mac. Good luck getting anyone to listen, much less come see the problem first hand.JimmyTheSaint said:Since I've had this rig and the relatively limited use it's seen - for me I'd say the P2 data disappearing act has been a pretty common occurance.
Perhaps Panasonic would like to come follow me around for a few days and we can find all the weak points of the system.
Spec-Comm said:Jimmy,
Make sure that the firmware is updated on your 8GB card.
Best regards,
Andrew Hoffman
JimmyTheSaint said:I was using a G4 Powerbook with an internal PCMCIA slot.
BenB said:You're hard pressed to find someone to believe you and I actually lost data on the P2 card itself. There's the mentality here that P2 is sent from God, is Divine, and more infallible than the Pope.
So much for MXF being some universal standard...
