Dan Keaton
Well, let's please clarify then -- Dan -- would both options require the Sony upgrade?
I don't believe that you're saying you can deliver 10-bit 1080p from the FS700's SDI port. That's what I originally thought, but you said it wasn't an up-res, it was actually taking the higher quality source, so that would require that you have an upgraded FS700, would it not?
Dear Friends,
Yes, this requires the FS700 hardware/firmware upgrade.
The HD-SDI in HD out of the FS700 upgraded or not, is 8-Bit in a 10-Bit word.
The 2K Raw and 4K Raw out of the FS700 is 12-Bit Linear.
We will take the Raw output, deBayered it, and perform other processing to obtain a high quality HD signal in 10-Bit.
It is also our intention to provide Log encoding to make the best use of the 12-Bit input format, while outputting 10-Bit for the compressed codec format.
Respectfully,
Dan Keaton
Convergent Design
