GoodLuck
I'm going to try my best to keep an update on it for those considering getting one. Feel free to post questions in here and I'll see if I can answer any. This is my first time trying to work with a video DSLR.
I took a college photography class and got an A in it but I'm no photography expert. So we'll see how it goes.
What was in the box ($899 at Arlington Camera)
The camera body (with a lens cap on it)
18-55 Canon Lens (with a lens cap on each end)
battery (LP-E8)
battery charger (LC-E8 charger)
Wide neck strap
Interface cable
Stero AV cable
2 CDs, (software, manual on CD)
Two manual books (English, Spanish)
The camera body (quick overview)
Built in flash, hot shoe on top, lcd monitor on back, a small speaker on the back to hear playback and a tripod screw socket on the bottom. From what I've ready similar cameras that are more expensive tend be made from more of a metal casing. This is a hard plastic casing. It's light and from what I've read, is not waterproof like other cameras.
First thought...does it hook up to a monitor?
Yes. It came with a roughly 3 foot a/v out wire with the red/yellow/white on the other end that I connected to my TV and it works, I could see what I was recording. So it will definitely work on a portable monitor/portable DVD player.
Thoughts on the lens..
The lens is an 18-55 image stabilized lens. This is good and bad. It's good because you can adjust it and it's essentially a few lenses in one. The bad is you can adjust it and it could easily get moved when filming video. The other type of lens most people get are called prime lenses. Those are fixed (don't adjust). 50mm and 85mm tend to be really popular. This cam including the 7D doesn't shoot full frame 35mm like the 5d Mark does. The guy at the camera story said the T2i and the 7D both shoot 24mm with a 1.8 magnification. How this impacts video, I'm not sure but is the main reason why the 5D mark costs more and is still a better camera. The guy at Arlington camera suggested I get a Tokina 11-16mm 2.8 lens and it would essentially then be full frame. He said it was the cheapest most value for the buck lens I could get. Basically a wider lens, you'll get more in the shot. I asked if it caused any warp to the image like fish eye and he said no. They have some 50mm primes for $100 up there but were out. I figured I'd try to find some used later if it's worth even shooting on this cam.
Extra stuff purchased
A 58mm UV filter ($15)
eFilm PRO Class 6 Speed SDHC Pro 150x 16gb card ($90)
Digital Foci USB 2.0 Memory Card Gateway with USB cord ($20)
Lowel Pro Camera bag with detachable lens case compartment ($40)
Portable lens cloth cleaner in a bag keychain (priceless)
The total damage with the $5 lens cleaner in a bag came out to $1,155.33 with tax.
The guy there tried to sell me on a three piece filter kit (UV, Polarizer, ND). I asked the noob question, will it work on most lenses? He smiled and said no, every prime requires a different sized filter for the most part. I was like, then I don't need the kit but I'll get the UV filter. (So avoid buying too many filters until you know what lenses you'll be using.) His suggestion was it's better to crack the UV filter in front than your glass on your lens. I've always kept one on my video cam lenses, so I got one. The card you get should be 6 speed based on what I've read. A lot of that has to do with how much it can transfer per second/minute to the card. This is more important for video so you kind of have to pay it. From what I've read the transfer rate on most Canon VDSLRs is ~44mbps. I think most people are fine with something around 30mbps. But you will always be left wondering if it really matters...if I get a cheaper one can I use it? If I get a more expensive faster one will my footage look better? Who knows. The card reader was mostly to reduce wear on the camera with the ports/SD slot as I'm trying to capture footage. Just make sure it says SDHC on the case and you'll be good for this particular camera. The one I got though support compact flash and pretty much all of them with little slots all over it for a wide variety of cards. It also doesn't have to be plugged in so could be used on the go with a laptop.
Important stuff to know ahead of time..
According to what I've read the SDHC 4gb card holds around 8 minutes of full HD footage (1920x1080) from people who've used the T2i so far. Canon's T2i webpage (link) claims 12 minutes at full HD on a 4gb card.
Based on Canon's testing standards using a 4GB card shooting video
Approx. 12 min. (1920 x 1080)
18 min. (1280 x 720)
24 min. (640 x 480)
File Format Capture at: MOV (image data: H.264; audio: Linear PCM (with internal mic: monaural, with external mic: stereo)
This means you will need an editing program that can handle converting H.264 to something you can edit/color correct. Or something that can cut it. All I know is CS4 (what I use) will allow it to be converted so it can be edited/color corrected. Based on what I've read, for MAC you might need the PRORES plugin to convert it. For PC, you could use the CINEFORM plugin.
Final Thought after purchase..
I bet I'm overpaying for something and can find it cheaper at Walmart or on the internet. Second thought, I should probably buy an extra SD card to be able to capture more footage..nah I'll wait to see if this thing even works right first. Third thought, I hope I don't get robbed on the way to my car. That guy in the store seems to be watching me.
Getting home..
I get home and remember the guy said to let the battery charge for 8 hours before using it because you can dramatically reduce the lifespan of the battery. So I did that and it seemed to be fully charged fairly quickly. Just to be safe, I left it for the full 8 hours.
Upon Awaking..
I put in the software disc to install it in the quad core PC and it took about 5 minutes to install and then restarted my PC. The install disc is dual PC windows/Mac so will work on both. It appears to have installed successfully on my Vista machine. Now I'm going to go off and test it out. Wish me luck!
battery (LP-E8)
Wide neck strap
Interface cable
Stero AV cable
24 min. (640 x 480)
However, the H.264 compression format requires that files be transcoded into a format better suited to editing, effects, and color grading; this would usually be Apple ProRes. The transcoding to ProRes can be a fairly time- and processor-heavy intermediary step that pays off later with superior speed once the post production process begins. That’s where EOS Movie Plugin-E1 comes in: It doesn’t eliminate the need for transcoding, but it includes several improvements in functionality and interface, making the experience of editing EOS HD Video footage with Final Cut Pro as fast and seamless as possible.
http://www.usa.canon.com/dlc/controller?act=GetArticleAct&articleID=3249
Getting home..
Upon Awaking..
