No, it's pretty much correct. That size is for video. For stills, the image size is 17.3 x 13.5 for 4:3, and 18.9-ish x 10.7-ish for 16:9 video.I think the Micro 4/3rd spec is wrong.
It states that the sensor size is 18.8mm x 10.6mm.
You're not reading that correctly. It's using a wide sensor, but the 22.5mm you're referencing is the image diagonal, not the width.Everything I've read suggests that it is 22.5mm x 13.5mm as it takes full advantage of the image circle.
