squig
Any shorts or commercials or anything besides test videos that were shot with the RAW hack?
Is it usable for projects yet?
I shot a narrative scene last week, I'm cutting it now. Totally useable if you know what you're doing.
Yes, but how do you get the actual write speed of the card (MB/s)?
Need to see where my card tops out at actually, not theoretically.
What kind of material do I need to test/shoot (something highly detailed, running water or the opposite for instance?) and what app is the write speed best read in?
Detail and movement don't make any difference, it's not compressed. Turn every Canon menu option off (the cheat is to choose a custom setting). Set the pic size to small jpeg or small raw, that frees up some ram for ML. Try setting stills to multi burst mode vs single shot. Run the ML benchmark test and compare your Kbay speed to others posted on the ML forum. The kbay speeds are all over the place unlike other cards which are pretty stable. If the speed is lower than other tested kbay cards send it back.
Ran the test. Komputerbay 64GB card was performing extremely well. 97.5/127 Read Write at 16384K, without turning anything off in the camera.
Until the card died 20 minutes later.
Oh well, back to the vendor. Time for another one.
The card "died" 20 minutes later? meaning it won't boot anymore? Or it won't record? is that 20 minutes while recording? I asked since you said 20 minutes later, and I figured the 64 gig will only hold around 18ish minutes of footage since 1 minute is around a gig.
Also, if your cam shut down after 20 minutes maybe its the auto shut off time setting in canon menu? I read in ML forum raw recording still makes the camera think that its idle and counts down till the time set for auto shutdown.
Or is it really your card thats faulty?
Meaning that the camera cannot format or access the card and sends the message "change card". Further, it cannot be accessed on a computer, except by disk utility, which sends a "failed" message after erase is attempted.
ML Benchmark can see it, but it is now apparently writing at 6.9MB/s.
Like I said, oh well, it was great while it lasted. :smile:
Agreed.Hehe. Having to reshoot a scene would end up costing me a lot more than the money saved on a few kompbay cards. Bite the bullet and get a Toshiba or a Lexar, both do 94-96MB/s consistently.
Then buy the lexars.Thanks for the update.
I guess Red was right all this time. Resolution is king (and raw video is queen.). All of those supposed modern HD cameras cant even touch the resolution of the 50d vids I've seen.
Am thinking of pulling the trigger on a 5dmk3. Have to say those Komputerbay cards have me worried though.
Not that I don't believe you but that's just hard to believe having worked with and knowing the nature of AVC HDThen buy the lexars.
The ml mk3 is detailed, but I can still out do the detail with my c100. I'm pretty happy these days to have both cameras as they cover all the bases I need to shoot.
Agreed.
Can you get full HD (1920x1080) for long recording times without dropped frames with these cards?
Oh, and what's the current state of sound in the latest builds?
