Barry_Green
Moderator
Hey, here's a red alert for Mac users: the firmware has changed in the cameras, and that means that you might have to adopt a slightly different workflow!
Mac computers don't allow formatting the P2 cards, so Mac users have frequently been just deleting the CONTENTS directory (and executing a force-delete). THAT WON'T WORK ANYMORE.
The new firmware won't recognize a P2 card unless it has that directory structure. If you do that, the camera won't recognize the card, and will instead display a message like "FORMAT ERR" or "DIRECTORY NG". This is, IINM, why the current version of P2 Genie's erasing of cards can't be used anymore either. They'll have to update P2 Genie to erase all the files within the directories, while keeping the directory structure extant. Until they do that, don't use P2 Genie's "erase" feature with a current-firmware camera.
Formatting the cards works fine in the P2 Store, or P2 Gear, or in camera. The question comes up when we're talking about hot-swapping cards for continuous recording. This is where you may need to adopt a slightly different workflow, because deleting everything off the card simply won't work anymore.
For Windows users, just use the "format" option; it'll do what you need.
For Mac users, you cannot just delete all the directories anymore. What you need to do is use P2CMS, select all the clips and then delete them. That'll erase all the files while preserving the directory structure. P2CMS is a free download.
