Shooter Veteran Mar 4, 2008 #1 I have some P2 folders in my Trash bin (amongst other junk). I can not empty any of the Trash because of the locked P2 files. Seems most of the P2 contents are locked files and it would be a major to manually unlock all of them (1124 files)
NoahK Hottie Mod Mar 4, 2008 #2 Are you sure they are not being used in any projects- like reallly certain. Noah
jcoxshooter Well-known member Mar 4, 2008 #3 try holding down the option and apple key while you empty the trash.
Shooter Veteran Mar 6, 2008 #5 I tried the options and none worked - thanx anyway. Other searches revealed this can be a Mac issue. (Google "locked mac files") I then found by accident I could open Inspector and when I multiple selected files I could unlock them as a group. As soon as this was done I could trash them. Bit painful but atleast not clip by clip.
D dirtysanchez Member Mar 6, 2008 #6 All you have to do is hold down the option key and then select "Empty Trash" from the finder menu. You can then delete locked files.
David Saraceno Moderator Staff member Mar 6, 2008 #7 Just hold the option key down when emptying the trash. Just did it today.
