Cees Mutsaers
What is the best way/technique to determine/set the luminance in a shot. My zebraces are set at 70 and 90 % but if I put the main object in the shot at 70% most of the frame is way over exposed.
If you're in manual iris and you expose for a subject in the foreground, a 70 - 80% zebra should start to roll over the highlight areas. On a person, this would be the top of the forehead, bridge of the nose or shoulders where there is a backlight or rimlight in play. Whatever is in the background area is going to expose in direct relation to what's in your foreground. If the background is more than three stops over or under the f-stop of the foreground subject, you might feel that you've over or under-exposed the entire image respectively.
I use DRS on the 300 and like it. It flattens the image somewhat, but I feel like the curve helps in contrasty situations. Like HDR (to an obviously lesser extent), it gives you more flexibility in post as details are maintained in the original image.
[What Ed says!]
mark - while i still use (just short of) 70 for my caucasian skintone target level, i think you're on the right track - mainly because in a digital world, if it's blown out, it's gone. if you're "under" you can always bring it back up if you're in a situation where you get post-production work done. i work mainly in news, and people want to see skintone at 70 right out of the camera as i rarely have an opportunity to get things tweaked before it hits the air...
correct - i have juuuuust a couple of z's on the forehead or brightest part of the face...Most who recommend the zebras in caucasian facial highlights aren't letting anything but the shiny spots crawl at 70 or 75%. Not the whole forehead.
Exactly. Zebras aren't a science, you have to interpret them. You decide how much zebra you allow to get the look you want. I set mine at 75% for skin tone and only allow the first sign of zebra in the skin highlights. To say that's old school is silly.
Ed
No simple answer for that other than to calibrate your camera's VF so that when you
look in your viewfinder you're confident that how you see it now will be how it
looks later in the edit suite, at least as far as exposure goes. I have 2 zebra settings on my camera, set at 75 and 100.
If there's sky in the shot the 100% setting keeps me from blowing out the sky. If there's
no sky in the shot then it depends on what *is* in the shot, dark trees, bright granite buildings,
etc. will determine what the 2 zebra settings look like. My camera also has a waveform monitor built-in, so I use that too.
Your experience as a photographer is going to build and build through experience. Your acquisition format is going to drive how you compose and light your shots. Film and HDR(v) are going to be comparatively less demanding from a dynamic range and contrast standpoint. For video, you need to keep whatever you want properly exposed within a narrow(er) range of stops. I love my foreground subject to be keyed 1 to 2.5 stops over the general background values. I don't always get what I want and the subject doesn't always lend itself to this style choice.
Productions roll around with tons of grip and lighting equipement behind them for good reason.
