starcentral
Placed my reservation for a Craft Camera today.
www.craftcamera.com
Wish me luck.
https://vimeo.com/163181999
Full technical specifications will be announced early this summer.
HD Video Element, Super 16mm CMOS Sensor with Global Shutter (1920×1080, 1280×720)
4K Video Element, Super 35mm CMOS Sensor with Global Shutter (4096 x 2160, 1920×1080, 1280 x 720)
Frame rates 23.98, 24, 25, 29.97, 30, 50, 59.94, 60
Fast and slow frame rate speeds at intervals up to 120fps
Recording Formats Cinema DNG and ProRes (additional formats will announced).
DIMENSIONS (W X H X D)
Video Elements: (97.15mm x 96mm x 39.68mm) (3.7” x 3.6” x 1.5″)
Store, Battery, Audio Elements: (97.15mm x 96mm x 33.4mm) (3.7” x 3.6”x 1.3″)
LCD Elements: (97.15mm x 96mm x 30mm) (3.7” x 3.6” x 1.2″)
Fully assembled cinema camera: (97.15mm x 96mm x 170mm) (3.7” x 3.6” x 6.6″)
According to http://resourcemagonline.com/2016/0...t-of-letting-you-customize-your-camera/65613/
www.craftcamera.com
Wish me luck.
resourcemagonline said:Recording capabilities include ProRes and CinemaDNG on high-speed CFast media. An SSD version will be released at a later date. Both the HD and 4K models of the camera are equipped with thirteen stops of dynamic range.
The 4K model comes with a Super 35mm size sensor while the HD model utilizes a Super 16mm size sensor.
Both cameras record high speed images up to 120 frames per second. A hot swappable EF, MFT, and PL lens mount called the Speed Mount allows users to swap lenses in seconds.
The removable ND Sled allows users to add a internal mechanical ND filter to the Craft Camera eliminating the need for external lens filters. Users can add different Control Links to remotely control the Craft Camera. The Control Link comes in three versions: Ethernet, Serial with LANC, and Wireless. Additionally the system has 2 mic inputs, 1 output for audio, HDMI and SDI outputs for video, dual battery operation, and hot swappable CF cards.
