PerroneFord
Deals in Lead
Is this just for Avid?
No, it's not. I use it in Vegas.
I use always uncompressed till I output.
And yeah, it takes some TBs of storage but I don´t care.
I always have the best possible quality during my workflow and it´s easy on the CPU - that means editing is smooth, fast and realtime.
Frank
From David At Cineform, he says...:
Cineform Low is a higher datarate than ProRes Proxy
Cineform Medium is a lower datarate than ProResLT
Cineform High = ProResSQ
Cineform Filmscan1 = ProResHQ
Cineform Filmscan2 = ProRes doesn't have setting that high
Cineform 444 not equal to ProRes444 -- CineForm 444 is RGB based, ProRES is always YUV
Cineform 4444 not equal to ProRes4444 -- RGBA vs YUVA
Cineform RAW = N/A
Perrone, using that to convert, do you notice a loss in quality? An increase in file size? Is it easier on your computer and can you edit and watch your footage without having to render files first? Easy to use?
Really appreciate if you have time to answer those questions. Would be great to find a solution to the difficult workflow of these mov files.
thanks!
I recently used ProRes 422 (compressor v3.1) for a short documentary project. The file sizes are absolutely ludicrous- I ended up with over a terabyte of data for a 20 minute short (granted I shot a LOT of footage). Each file was 4-5 times bigger than the raw clips. Since then I've tried using the lower quality version, which has resulted in somewhat manageable file sizes that stutter frequently during playback. My system is a six month old 2.8 core2duo MBP with 4mb of DDR3, so I really can't believe it's not watchable with anything but the full blown ProRes.
How does everyone deal with these insane ProRes file sizes? Do I really need a more powerful system? Also, I'm running FCP Studio 2, is "ProRes LT" only available in later versions?
Thanks for the great answers/information.
It sounds like the real benefit is for color correction but I still don't get how converting a file to 10 bit 4:2:2 when the camera writes the file as 8 bit 4:2:0 does anything more than just create a larger file. The only new data being added is 1's and 0's, no new information that pertains to color space.
How big does your uncompressed file get at full 1080 25p per minute of material?
looks like cineform might be the best way to go then.
quick question, which software am i looking for?
Cineform Neoscene
Cineform Aspect HD
Cineform Neo HD
or do they all offer the conversion required to grab my 7D footage, bring it to 10 bit AVI and make workflow a whole lot smoother?
