Dennis Wood
DVXuser Sponsor
Barry, if the you do the test at full wide zoom, it looks like the aperture stays slightly more open than if you zoom in 100% on a bright source. In other words, with the 50/50 zebras at 70% when locking exposure, -11 does not seem to completely close the aperture. Looking at an angle of about 45 degrees (using an overhead CF bulb) you can see the reflected light in the aperture opening change colour suddenly ..and it does it twice. I observed the exact same type of ND filter (2 stage that slides in) from the GS400 looking through the lens. An led cap would work perfectly with what I tried in TV mode. Instead of using zebras at 70% and locking exposure when 30-50% of the frame is in zebras, an LED array in the cap could be used combined with metadata viewing (on the other HDV cam) to absolutely set the baseline. I'd buy that cap!
Btw, the only way I could visuallize the aperture and ND filters was with the cam fully zoomed out. That brings the rear element forward so you can visualize it.
On the iris side of things, I haven't tested the HV20 at all for diffraction due to aperture blades etc, but I suspect like the other cams similar to it, f4 would give the sharpest image. I have observed some vignetting introduced from the video cam's aperture before when using an adapter, so some testing with your selection of 35mm lenses would be a good idea if you plan on stopping the camera down. The stinker with these consumer cams is you can't lock in f4 and dial in an internal ND...meaning if you're into the internal ND's you're also using the smallest (not ideal for image quality) aperture.
