Gordon Prince
Barry_Green said:No. That's the problem, in a nutshell. You can only assure shutter speed, OR aperture, but not both.
So you can set it to 1/48th, but you might get all sorts of gain in your picture, without you even knowing it.
OR, you might force the iris to f/2.8 with (presumably) no gain, but then your shutter speed might change off of 1/48 (again, without you knowing it).
Now you see why we're concerned about finding out the truth, right?
Okay. But doesn't these posts help at all? You said no word on these tips.
Emanuel said:Other hints there go always to the same thread destination (probably the best way to answer it):
http://www.dvinfo.net/conf/showthread.php?t=88596
http://www.dvinfo.net/conf/showthread.php?t=87901
Here is another one:
http://www.dvinfo.net/conf/showthread.php?t=90064
e-steve said:Based on this, I think I've kind of figure it out...(at least how to keep the gain constant)
1) Press the Func button
2) Go into Tv mode (shutter priority)
3) You can adjust the shutter here with the joystick
4) Press the Func button to turn off menu
5) Press the joystick (center)
6) Scroll down until you get to EXP (joystick down)
7) Press up once on the joystick, -/+ will turn white
8) Set EXP to 0 buy moving joystick left/right
9) Press the joystick (center)
- AGC should be off now...I am assuming you guys figure this out too...but wanted to spell out how I did it in case others may be wondering.
Did you guys notice the DOF when in Av setting it to 1.8? Not too bad, buy I just did a few tests sticking out my foot in front of me... LOL will test more on the road this week...
jenningsp said:i don't have my HV20 yet. but from my reading i've worked out this chart. could one of you test this out...
in TV mode.
put in in either spotlight or auto mode then cover the lens (make the picture pitch black) wait till the camera adjust then push the exposure button.
put it in auto mode to control the gain.
i'm not sure if the gain goes up to 18db. it might only go up to 15db. if that's the case then 0 = 15db, -1 = 13.5db... -9 = 1.5db.
-11 = 1.5db
-10 = 3db
-9 = 4.5db
-8 = 6db
-7 = 7.5db
-6 = 9db
-5 = 10.5db
-4 = 12db
-3 = 13.5db
-2 = 15db
-1 = 16.5db
0 = 18db
put it in spotlight mode to control the aperture.
-9 = 8
-8 = 6.8
-7 = 5.6
-6 = 4.8
-5 = 4
-4 = 3.4
-3 = 2.8
-2 = 2.4
-1 = 2
0 = 1.8
when i say 0 i mean where it starts from in the exposure setting. it should start from that point but it could actually be +11. i'm not sure. do you understand what i mean?
this is just theory for now. the values could all be wrong. i'll fine tune it all when i get my HV20![]()
rawfa said:This might help http://www.dvinfo.net/conf/showthread.php?t=85370
I don't have the HV20, so I cannot try this, but apparently it's the way to go around this "problem".
