Robert M Wright
This doesn't sound very good at all.
If it's happening in the camera without going near the computer, then it must be a hardware problem. But if it's happening across two different cards, that points to the camera being the problem, not the cards. Do you know anyone else with a P2 camera that you can try the cards in, just to narrow it down for sure? If they work fine in someone else's camera, then that would point to your camera being somehow defective...
Had a similar issue with an hvx200(not A), except the blocks were gray, after a couple different techshops looked at it they said the p2 drive needed replacement and panasonic stopped manufacturing them for this older model, go figure. I use the same p2's in a hvx200A with no problems. Very worrisome glitch as I want to get a 170. Who knows when they stop the production line for those 170 p2 drives. That 200 was like 2 years old.
If it is the P2 cards does anyone how long they are guaranteed for.
I guess in theory as my E-series is less than 4 weeks old it should be guaranteed, but the A-series is probably 2-3 years old????
The odds of both cards failing (especially within days of each other) is slim to none.
That's a great idea. Maybe test it feeding into onlocation or something like that over firewire.So, if this happens to others in the future, is the best alternative a Firestore or DataVideo DN-50?
x
I stand corrected. Thank you, Jan. Its my producer's cam, and I am going by what they had said to him. I just emailed him to see what their deal is? Sorry about the confusion.Hi,
Not sure which service shop gave you this information but I checked with the guys in my service shop and they still have all the parts to fix an HVX200. All parts are available.
Hope this helps,
Jan
