finally i found the problem with the AJA IO express - with the PAL GH2 it does not work because there is no 50i input... - but i made a test with the NINJA and it works perfectly!
Since the camera outputs 50i at the HDMI and i would love to convert it to 25p instead of 24p but keep the advantages of this great scripts. I was trying around with the "Assume(24000,1001)" line, changing it to "Assume(25,1)" - without result. So i guess i will have to get rid of the pulldown??
Thanks for your help -
Did you record at 24p?
If you've applied Ralph's script, and changed the line to AssumeFPS(25), this will do a simple PAL speedup (i.e keep same number of frames, just speed it up from 23.976)
If you are recording analog audio , add "true" to speedup the audio as well
AssumeFPS(25, true)
If you were feeding that .avs script into ffmpeg to encode to DNxHD , you have to modify those parameters also (the parameters in the earlier post are only valid for 1080p23.976)
For 1080p25 ffmpeg DNxHD encoding , use -b 185M , -b 120M , or -b 36M (for 185Mb/s, 120Mb/s and 36Mb/s respectively) . And to pass uncompressed audio through, use "-acodec copy" instead of "-an" in the ffmpeg commandline
Note it's "AssumeFPS" not "Assume", and check for the latest script, he's added some recent improvements
