memphishills
Broken devices. You've got to be kidding. Talk about hyperbole.
And nobody is talking about not having problems resolved, but it seems that most of the problem occurs at the edge of the camera's performance. That's hardly broken. Annoying, yes. Workable - absolutely. Will it get fixed? Most probably.
Well I guess if my car were to blow a tire, but the rest of the car worked fine, I should just keep on going, since its just a small part of the bigger picture right? When I buy a camera to shoot video, which might I add is a highly talked about feature from Panasonic themselves regarding this camera, and the video doesn't perform properly, I should just accept that? If a key element of your product does not work 100%, I would consider that broken. If it was just a case of not looking so hot at high ISOs, or focusing poorly, then sure, limitations of the camera. But this is an obvious defect relating to the way the sensor is operating, as from what we can see, it's not on every model, and it goes away under certain circumstances. Seems like more a defect than an annoying camera quirk. If you had a crack in your window, but it still closed, would you not consider it broken?
