GH1 firmware research volunteers required
May I ask a question?
The firmware V3.22 can use language option in g1 and gf1,why the firmware V3.25 can't use it ? Is it any problem?
If you are talking about v3.22 preview screenshot, it is very simple.
It is just testing of selection made patch, no such actual patch for G1 and GF1 ever existed.
yup first time using it. My gh1 has the 1.32 update but I can't seem to get the hacked update to show up on my camera. I have been saving the files over and over again but still doesn't work. And i believe that I have the most recent hack. v3.25?
First, use empry SD card.
Second, upload original and saved firmware to rapidshare or hotfile and give me a link.
Sorry,that's my fault.
I mean firmware V3.20,japan --> English function can use on GF1.
PTool 3.26 Released
Interface language patch changed, now allow to select
any language you like for any region (GH1 only).
Battery patch changed.
Reformated my sd card and still doesn't work. Uploaded the files to rapid. Included a pic with my settings just too make things easier on you. Good luck, you've been a big help to me and everyone else already. :)
I don't see any problems, other than file name.
Use "GH1___133.BIN' instead of "GH1_133.BIN"
Yes - I had the same issue. Tester is correct. Filename is important. Must include two underscores (__) between "GH1" and "133.BIN" or else camera will not recognize the file.
WOAH! Big problem. Was able to upload with the same file i uploaded but it seems to be messing with my camera. Whenever i try recording the o.s. seems to freeze up. I can still see whatever i point at with the lcd but it won't record and the buttons seems to freeze up. In general the buttons seems to freeze up on standby mode. Can't even turn the camera off without taking out the battery. Can still take pictures though.
Update: It seems as if it records in mpeg HD correctly... only has the problem in any format of AVCHD
Update: It seems as if it records in mpeg HD correctly... only has the problem in AVCHD
OK. Try to read help hints befory doing something.
Look at your 1.280.000 audio encoding rate and see that help crearly states that it'll freeze your camera during recording.
Third-party battery work ok, btw?
Ahhh I see, silly me. Lemme try changing the audio and updating it again but the 3rd party is working just fine. Don't know the name of my battery though since i can't read whatever language it is... but it works so thats good.
Sorry, I can't understand you.
Current PTool version also works for GF1.
PTool 3.26 Released
so,V3.26 firmware about language part isn't use on GF1,right?
My question is V3.20 can use in GF1(Japan-->English),why V3.26
can't do that?
Thank you !!
And it didn't work before, right?
As some batteries have necessary chips and work without patch.
And you don't need MJPEG 30->24fps also, as it is for research only and just skips frames.
can't do that?
v3.26 also have working Japan->English patch on GF1 (same as v3.20!).
Just on GH1 patch is now more univerfal and allow you to specify any supported interface language.
I haven't tested it with the older hack tool since I wasn't able to update the camera (because of my mistake in naming the file) but the newest version seemed to do the trick, since it didn't work with the original panasonic update. I'll be sticking to just the 3rd party update since the freezing in 24p and skipping in mpeg is a problem. But you have made good progress. Good luck on finishing your project.
Freezing in native 24p is only during play mode.
Good thing is that third-party battery patch is now working.
