GH1 firmware research volunteers required
Very good. Thanks for report.
This is almost exactly the expected behaviour (in case it won't work from first attempt).
Hmm, but its not what I expected when i applied the patch ;-)
I went through the thread, but cannot make sense out of your statement, can you please explain?
My statement was clear. I expected it to either work or, in case it won't work, that bahaviour will be the same as you described.
Ah, I see. Guess I got confused by "first attempt" hehe.
Anything else I can help you with/contribute to make the battery patch work?
Download Ptool again.
Battery patch have been changed.
Risk is increased, as we moved to lower level (but not the lowest possible).
Even if bahaviour will be the same, your report is very important.
For future tests it could be helpful if you moved the camera to see if there is any difference in the quality of the final output. Static video is easy to encode, just pan the camera back and forth a few times when you do the test and we will see a lot more.
Such approach is complete waste of time as you need complete repeatability of results, and panning is not good.
Shooting something moving at same speed (like fan, etc) is another matter.
PTool Hack help:
The hack tool seems to work perfectly fine for me and I am able to change the new firmware that came out for panasonic. But for some reason i cant load it onto my camera. I put it in the root file of my sdcard but it doesn't load. No matter what I put as the increment for the version change it still doesn't show up. Is it because I already installed the new firmware to my camera...
Please, try to read all instructions from Panasonic firmware update site carefully.
Fo example, your battery must be fully charged, etc.
Charged the battery fully but still getting the same problem? Am I the only one with this problem? Hope my camera's not faulty or something...
Yes you are the only one. I already pointed you to read Panasonic instructions.
If your current firmware is v1.32 and you downloaded proper GH1 firmware using link at first page it must go without any problems.
hi there, and many many thanks to tester13 and everyone involved in this awesome project. couldnt join the fun yet, as i'm still really jammed with work... gladly donated anyway :)
just a thought:
wouldnt a 24p through a 48i fix the problem of previewing the video on the camera AND still get a stable 24p? (without pulldown needed)
sorry if this option has been discussed earlier and i missed it.
thanks again for the GREAT work on this
nox
just a thought:
It might work but why unnecessarily waste the bandwidth on doubling the frame rate, when it can better be utilized by carrying less compressed content?
Just my $.02
probably... i'm no specialist here, but i would just assume that 48i shouldnt use more bandwith than straight 24p. i just assume that this could be a more processor friendly way to get a stable 24p at the end, as it seems that its the way our beloved gh1 processes the video, and get the preview working aswell... i sure might be wrong
May I ask a question?
The firmware V3.22 can use language option in g1 and gf1,why the firmware V3.25 can't use it ? Is it any problem?
What a great job from tester13. Go ahead... I have made my donation right today.
Just a question: Is there a plan to change the language from English to German?
I bought my GH1 in central america and have no "German" option. I am using the PTool
for switch to "PAL". It works fine. Now I like to have the german menue, if possible.
