GH1 firmware research volunteers required
In this case do the following:
1) Find in this thread instructions how to set your region (this is possible one time only) using service mode and set it to Chinese version.
2) Check if interface is now normal.
3) You can later use patch in other areas.
I believe it is best solution.
The region code for Simplified (Communist or Mainland) Chinese is GK, for Traditional it is GT.
Thinking about it a bit more, perhaps the letter K stands for Kommunist?
Who knows.
As soon as we'll have GF1 body most patches will be ported to GF1.
So, make them donate, and it'll be faster.
Yes! :2vrolijk_08:
That promise is sooo awesome! Was unsure if the patch might stay for GH1 mainly...
Makes me go and use the donate button right now!
I am so happy to have another product for which some intelligent geeks are producing a firmaware hack... love my CHDK-improved Canon point-and-shoot, love my Rockbox-improved MP3-Players (and kept buing new ones on the criteria that they can be rockboxed)... will love my hacked GF1!
Panasonic should pay you Hackers, actually, as you are improving their product.
Keep up the great work, Tester13 and all other GH1-Hack-pioneers!
Also thanks to Car3o for starting the possibility for donations and thus for getting the needed Hardware to Tester13!
To be short - you are wrong here.
No actually he isn't. Wrapping progressive frames in interlaced format has been done with PAL for a long time. It doesn't have to be native - the benefit comes from not having to do a complicated pulldown, and that's only relevant for 24p wrapped in 60i which uses 3:2. 25p in 50i can be dropped straight on an NLE timeline without pulldown. So 24p in 48i etc. is worth trying because the camera might also be able to play it back.
I know you're going to kill me, but I just used this firmware on a real shoot.
I didn't play too much, I simply converted PAL to NTSC and removed the 30 minute limit. I also tried one with the interlacing disabled, but that caused the camera to lock up upon playback, so I made a new version without that.
And it worked fine. No issues whatsoever on set, footage looks fine. I can provide sample clips if need be (it was low light/party lighting.) I transcoded and passed it off to the editor, who is having no problems in Final Cut.
So thanks a ton, and fantastic job.
But I have one request...real timecode. You know, hours:minutes:seconds:frames. Not this "12m 8s" crap that's utterly useless on set.
I think it's been mentioned already...provided Tester13 gets his hands on a GF1- you will have your patch:shocked:
I know it's mentioned in this forum.
But outside this forum, many people still perceive this patch as GH1 only and will not port to GF1.
I'm not pushing for GF1 patch, just want to let you guys know this.
had my first shoot tonight with the english patch and 24p, loved it. If I wanted playback I simply put my card in a laptop onset and viewed the footage. Went swimmingly nevertheless. Once I get home I'll update my thread with grabs.
Nice Car3o!!- looking forward to some footage!
Keep GH1 v1.22 please
One note
We may drop GH1 v1.22 support soon as all patches are now ported.
If you are still using v1.21 or early version because of battery, it is time to update to patched v1.32 also.
Oh my! Please Tester13, will you drop the idea of dropping GH1 v1.22?
I have upgraded my GH1 more than Panasonic can do, with your help.
Changed language to English. I use Korean though.
Use 1080/24p instead of 1080/60i, with GOP size 6.
When it comes to 760/60p, GOP size 6 works okay.
Maximum bitrate is set at 30Mbps
Bitrate Adjustment 1 is at 20Mbps.
Bitrate Adjustment 2 is 22Mbps.
In my case if BA 1 is higher than BA 2, ie 22-20, it crashes.
BA 1 should be 20Mbps and lower. (Higher than 20 causes crashes)
BA 2 should be 22Mbps and lower. (Higher than 22 causes crashes)
Under above settings, it works real smart and smooth. Thanks!!!! :2vrolijk_08::2vrolijk_08:
Then my only problem.
I am not able to use the new firmware v1.32, official or hacked.
Actually the last time I upped hack formware onto my body successfully, the verson increment numver was 13 (it gave me 0x012F 303) and I stopped.
I guess the increment number 14 would result in 0x0130 meaning v1.30. Am I right?
Then the new and official firmware came out, so did yours.
As soon as I got the 1.32 firmware and your new tool, I first tried to upload the not-hacked official version. Oh no! It didn't work. Failed to recognize the official firmware displaying "No Valid Images blah blah ..." :Drogar-KnockedOut(D:Drogar-KnockedOut(D
Then I tried to upload new hacked firmware using increment numer 1 resulting in 0x130, and unfortunately and unexpectedly it didn't work either.
I have no idea what I have done wrong about.
Currently I have no choice but to use the firmware v1.22. Internally it's 1.36 (0x136) though.
Any tips leading to something like a solution would be greatly appreciated.
And Tester13, I humbly request you plz not to drop v.122.
Should I have to just sit and wait until the next official verson 1.4? :undecided:undecided
Since the 24P is not being spread out over 60 individual video interlaced frame/fields, and instead in 24FPS discrete frames; would this not make for better compression?
Can you also view the thumbnails ( not play them ) however just see the thumbnails without crashing..?
Michael Pappas
http://www.pbase.com/Arrfilms
This sounds really encouraging. Hats off to you and Tester13 for getting this off the ground. Look forward to seeing some footage.
Here is solution to your problem.
Load v1.32 and use high version incriment.
If for patched v1.22 you have v1.36 now.
It is not enought to make v1.37 from v1.32.
As firmware also have release number and these number are closer than version numbers (0x6A for 0x132 and 0x61 for 0x122).
Now your increment is 0x14, and instead of 0x15 you must use 0x1D or higher.
Is it possible to use Eye-Fi cards with GH1?
Main problem with them is that they are locked and operate at high level.
If it will be possible just to mirror SD Card FAT on main computer in real time it will result in realtime FullHD monitoring solution (with slight delay, of course).
As some players are able to play incomplete MTS files while they are being written.
P.S. We all hope to see some beautiful girls instead of cars at night. :engel017:
I can't use the firmware v1.32 and now I might find the cause.
Right before the firmware v1.32 came out, I used the increment number 13 and though it was version 1.29. Alas, I checked the ptool and found out it was 1.2F, not 1.29.
V1.29 is the increment number 7.
So I suppose if we use the increment number 8 and above, we don't use the new firmware v1.32. That's exactly what I'm experiencing.
Then I want to know if there are other GH1 testers who intensively test the ptool reaching the increment number 7 and going on beyond the limit.
Or is there any limit actually and just my body is too picky?
Thanks for the quick and valuable answer, tester13.
And for a double check...
My last increment number on v1.22 was 20. It shows the value is 0x136 310.
Then exactly what increment number should I use on v1.32?
You said I should use 0x1D or higher, but I don't know what number it is.
Maybe I am wrong thinking 0x136 means internal version 1.36.
I really appreciate your philanthropic work and personal advice too.
If "0x1D or higher" means the value, it seems that I should use the incrememt number of 7118 or higher as 7118 results in 0x1D00. Do I understand you correctly? Please forgive my ignorance if I'm wrong.
Planning to buy Japanese version GF1.
Q1. Can i use this Ptool 3.26 to change Japanese menu into English menu?
Q2. Do i use Japanese GF1 firmware v1.2 or Global GF1 firmware v1.2 ( 10 May 2010) to patch it?
Please do advise! Thank for advance! :D
No, it means increment 0x1d or higher (version number will be 0x132+0x1D :-) ), i.e. 29 or higher in decimal.
