GH1 firmware research volunteers required
Test result:
M-JPEG mode
Codec ID : jpeg
Duration : 10s 0ms
Bit rate mode : Variable
Bit rate : 17.5 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Bits/(Pixel*Frame) : 0.793
FHD mode
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Duration : 9s 960ms
Bit rate : 14.9 Mbps
Maximum bit rate : 16.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Frame rate : 25.000 fps
Original frame rate : 50.000 fps
SHD mode
Duration : 10s 120ms
Bit rate : 15.3 Mbps
Height : 720 pixels
Frame rate : 100.000 fps
All stable.
File link here: http://rapidshare.com/files/385766419/new_firmware_video.zip
Regards
NURBS
FHD mode 1080 24p no pulldown is working perfectly for me. I even dropped it into a 1080p AVCHD timeline in Premiere and was great! Though it did freeze in camera playback, which is no biggie for me.
Japanese to English also working.
Just to confirm, as haven't received my camera yet, this patch works on latest firmware. Is it normal for any hacks applied to the video recording options don;t pay via the camera?
Cheers
DOes anyone know if CS5 premiere can edit GH1 native? I read here that it can but don't know what "with sequence preset" means.
Native support for DSLR cameras Edit video from the latest DSLR cameras. New native support means that you never waste valuable production time transcoding or rewrapping, and always have access to the original file’s pristine quality. Adobe Premiere Pro supports video shot on the following DSLR cameras:
Canon EOS-1D Mark IV,
Canon EOS-5D Mark II,
Canon EOS 7D,
Nikon D90,
Nikon D300S,
Nikon D3S
Nikon D5000
Panasonic Lumix GH1 using AVCHD sequence presets.
http://help.adobe.com/en_US/premierepro/cs/using/WSF57F84EC-928C-4a1f-82BC-77396CE191B6a.html
Canon EOS 7D,
Nikon D90,
Nikon D300S,
Nikon D3S
Nikon D5000
I've just got CS5 installed so i'll check out GH1 native editing tomorrow. I'm a FCP user mainly though.
I would love to test out Edius, but I'm a Mac user without Windows. =-[
Looking forward to seeing what you have to say nobbystylus.
PTool 3.20 Released
PTool now supports multiple firmware revisions and multiple cameras
All working patches and MJPEG 24p patch ported to firmware v1.32
Research and tester oriented patches will stay on v1.22
Added G1 v1.50 Version and Japan->English patches
Added GF1 v1.22 Version and Japan->English patches
Main surprise is addition of interface switches for G1 and GF1.
As I found a way how to do them without any reversing of firmware :-)
Any other patches for this cameras will be available only after we'll have them at hand, because of legal issues.
Wow!!!!! Incredible!!! :Drogar-BigGrin(DBG)
Premiere Pro CS5 work perfectly with the GH1, use AVCHD 1080p sequence presets or AVCHD 720p Pal or Ntsc, is really faster than CS4 and also stable, for my is a must have, cause my work is mostly in AfterEffects and also can read the GH1 files in After too, i have a Mac Pro dual Quad Core and the renders are really fast thanks to the 64Bits version.
Cheers
Can't tell if the cadence is right on the MJPEG without movement. And the other two clips are giving me this strange pause every second on playback. Anyone else seeing that?
EDIT: Ran the MTS files through Neoscene which gave me the frame jump every second. Reran them through Voltaic and the playback is smooth. Weird, looks like just a neoscene issue.
Canon EOS 7D,
Nikon D90,
Nikon D300S,
Nikon D3S
Nikon D5000
Pretty much anything out there (Premiere CS4, CS5, Vegas 9, Edius) can edit GH1 AVCHD natively. FCP is the only one that lags behind a bit.
I think I've put my camera in service mode, although I'm not quite sure how I did it. I now have a ROM Backup option in the Setup menu, that I don't think was there before. Can someone else verify whether they have this option?
