GH1 firmware research volunteers required
first page. everything there is to know is just about covered there.
Hey man yeah I read that first page already, and still kind of confused... these are things that you've accomplished? 24fps Mpeg 720 recording etc... I guess Im just kind of looking for what the end goal you guys are hoping for... is that everything listed in the AVailable patches that you hope to accomplish or have accomplished? Are there other things you're hoping to achieve?
Improved compression to reduce or eliminate mud from fast pans in 1080 mode.
Pal/NTSC switchable for region free shooting.
MJPEG 24P for totally mud free shooting and native 24P shooting.
1080 24P avchd to avoid pulldown removal in post.
AGC disable.
Basically the goal is to make this camera function better than it does since Panasonic isn't going to release a firmware that accomplishes this. Even if it's just a matter of enabling native 24P in 1080 to avoid the annoying hassle of pulldown that's still a huge improvement.
Try to read all below "Major issues for today are" on first page.
AGC disable.
I also siggest you to read first page.
As number 2 and 4 are done.
haha, yeah yeah......I'm off Tues so all is good there. Beside, we're still waiting on that adapter to be delivered, so no biggie. Which is ordered and on the way. As far as funds go. There is still $60.00 in the piggie and no sd card has been ordered yet. I'm looking locally first and then going to discuss whether or not to buy online.
This looks confusing. Are we down to $60 on funds?
I think it might be a good idea to start a thread discussing the user end of the firmware patch and keep this thread reserved for the work and testing of the patch?
As for sensor related things.
We are yet to understand this, as constant WxHxfps suggest constant read rate and it can not be coincidence. But we can have some internal binning algorithm and reading of whole line scaled to suggested resolution.
So, more shoots are required, including 16:9 photos and video test charts.
P.S. LX is costly and it is not an option due to encrypted firmware.
I don't like this idea.
What exactly do you expect from "user oriented" thread?
With time we'll move to dedicated forum and such threads will be ok, but today they are just nor very useful.
I understand what he is saying. Even though this thread shows enormous potential it can be very technical for some people at times. But at the moment I think Tester13. Lets just let the man do his work and discuss the benefits latter.
Hi, short question...
I use a PAL version and have fw update 1.21 on it, which version increment should i type in in your ptool to make an new fw update?
1.21.1 or something?
Another question, what does the 24/25p native patch exactly for my pal camera?
i have read all sites in this thread because it´s very exciting what happens here, but my english is not so good to understand all youve written here, maybe anyone could write the first page with all infos also in an german version?
Google translation can be used to make english to deutch translation :-)
Use default increment (1)
Native is native, 25p video instead of 50i.
thanks tester13 :) sry, i know, you are doing a very very good job, but sometimes also google translation could not do it´s best ;)
Just the fact that people want to speculate about many different aspects of the GH1 hack but not all is pertinent to the research done here. You seem to indirectly suggest it yourself, this was my motivation for my suggestion.
Guys, please do no go to banding and rolling shutter things.
We can't fix them, so it is better to discuss in separate thread,
So i have tried a patch on my pal version..
Version change - 1
30min limit removal
native 24p/25p
recording without problems
but
connect the camera to usb, camera freeze... no connection.. battery remove helps...
turn on camera an press the play button, it freezes the camera too.... also battery remove helps...
has anyone the same problem?
edit:
i made a second fw only with 30min lim. removing, all is working fine, so there is a problem with 25p native?
Try to delete all native footage from SD card.
Camera can't play native 25p videos, so this can be only reason for freezing.
Native patch changes only encoding settings and can't affect any USB connection parts.
Use SD card reader next time.
okay, so, the camera can work with native 24p but not with native 25p ?
So do i have to change the camera from pal to ntsc to work with native files on camera?
