GH1 firmware research volunteers required
Ou sorry I don't entered new values. Please little bit waiting.
I don't know why 25fps and NTSC but it been in original firmware ;-) maybe it Mediainfo bug. Or gift from Panasonic :-D
Very interesting thing:
When
VA bitrate adjustment (X) - 20000000
VA bitrate adjustment 2 (X) - 25000000
VA bitrate top limit (20->25Mbps) (X)
Camera can't recording video and go to deep freezing ;-) but if you change to this value.
VA bitrate adjustment (X) - 18000000
VA bitrate adjustment 2 (X) - 20000000
You have this picture.
SHD
General
Complete name : E:\PRIVATE\AVCHD\BDMV\STREAM\00002.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 161 MiB
Duration : 1mn 33s
Overall bit rate : 14.5 Mbps
Maximum Overall bit rate : 20.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Duration : 1mn 33s
Bit rate mode : Variable
Bit rate : 13.8 Mbps
Maximum bit rate : 16.6 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Original frame rate : 100.000 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.299
Stream size : 153 MiB (95%)
and FHD
General
Complete name : E:\PRIVATE\AVCHD\BDMV\STREAM\00003.MTS
Format : BDAV
File size : 195 MiB
Duration : 1mn 44s
Overall bit rate : 15.6 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 2 frames
Duration : 1mn 45s
Bit rate : 14.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Frame rate : 25.000 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.285
Stream size : 185 MiB (95%)
Can you try to max out the recorded bitrate by recording tons of movement (pans etc)? Right now it's not clear if the 20mpbs upper limit is actually real or just a marker.
mjpeg 24p don't work here, camera freezes when stop recording and file is corrupted. Mjpeg mode is very interesting, no mud and if the bitrate can be improved the quality will be fine.
I set 40mbps cause 24mbps will be as muddy as 17mbps. This is why mud happens, the codec don't use B frames, just I and P, in 24p stores "I frames" every 15 "P frames", and in 60p "I frames" every 30 "P frames". In 60p every "P frame" gets 30k on average , the mud appears when the scene changes too much between P frames, or even when the scene is too detailed, like grass or sand.
By incrementing bitrate to 24mbps "P frames" will get about 40k averaging, not enough to get rid of mud. Without another codec tricks , we need at least 30-35mbps at it seems difficult to get it work.
The hacked gh1 videos, shows only 1 initial "I frame", and from there only "P frames".
May be codec can be fooled to think its recording 12fps at 17mbps, averaging 60-70k per frame, but really is recording 24fps.
Firmware changing only 'Maximum Overall bit rate' but video bit rate don't changing. If I make no move video - bit rate is 13 Mbps. If I make lot of move camera - bit rate is 16.4 Mbps.
I'm changing value to this digits.
VA bitrate adjustment (X) - 19000000
VA bitrate adjustment 2 (X) - 21000000
Regards
NURBS
Glad to see all the hard work getting put into this. Really exciting stuff!
Is it possible for these tests to be preformed on a Mac? Or is it strictly PC only?
And as for the donations...Did we still need any?
Wow, just got home from work and there's like 10 more pages to read. I was thinking today that I could part with my GH1 since I have a T2i and I'm not a professional photographer or anything. Not to add a kink in the decision, but I'd take $600 for the body with battery, charger, etc. Mine's a US model in perfect condition. I donated $50, so I'd essentially be getting $550 for it. But, there's something for having my camera be a part of history :) I'm cool either way if everyone wants to go with camera land.
But remember you'll want your GH1 when more breakthroughs occur :)
Thanks for everything so far. I have two more suggestions.
I have a PAL GH1 and really want to shoot 1080p/24 instead of 25. Any way we can get this?
Also, a frame-accurate real timecode display would be fantastic. "X hours X minutes" just doesn't work on a real set.
Thanks!
So I was thinking about how fast donations have been coming in, and it seems in a few days we'll have enough for someone to buy a GH1 body. But then what? We might have to wait 2-3 weeks for the delivery from eBay.
Like many others I'm anxious to see tester13 get what he/she needs to move forward. As an alternative: is there anyone willing to express ship their own GH1 to tester13 in exchange for the donation money? This would reduce our wait time significantly.
I might consider this, but I'm planning on using mine in the next 2 weeks.
I'd be willing to do it but it's a pretty scary proposition to send out an actual camera with only the promise of money forthcoming. How can we mitigate the risk?
Path just said he`d take $600 for the body etc..
And i just wondered Path,why would you donate $50 and sell your GH1 ?!!..
`Wow, just got home from work and there's like 10 more pages to read. I was thinking today that I could part with my GH1 since I have a T2i and I'm not a professional photographer or anything. Not to add a kink in the decision, but I'd take $600 for the body with battery, charger, etc. Mine's a US model in perfect condition. I donated $50, so I'd essentially be getting $550 for it. But, there's something for having my camera be a part of history :) I'm cool either way if everyone wants to go with camera land.`
Well, my main frustration with the GH1 is pulldown removal, which is why I'd like to see the firmware modified. The T2i doesn't require this. On the flip side, the versatility of the mirror-less design of the GH1 with regard to lenses is a huge benefit, which the T2i can never claim. I prefer to think in terms of lenses as the investment, while the cameras will always be updated to be better and better. I can buy another GH1 body or a GH2 if/when that ever comes out.
Anyway, this isn't a thread for discussing the pros & cons of camera models. The offer stands, and I'm essentially out around $50 either way. I just wanted to support the effort, and still do. I realize with the money now available we need to be careful. Ebay has its risks, but I guess I'm just some guy on a forum. I agree that it needs to be a collective decision, and like I said it's fine with me either way.
MJPEG update: camera freezes only when recording more than 4 o 5 seconds, 3
second videos are OK, fluid 24p and 24mbps.
Will recording at a higher bit rate risk damaging the sensor? Same with 1080p mjpeg? Why do the canon's overheat and the gh1 doesn't?
GH1 is designed from ground up to use liveview, which is probably why it doesn't overheat from using liveview.
