GH1 firmware research volunteers required
Here is screenshot of early working new PTool version :
Advanched functionality not shown here yet :-)
The AVCHD specification defines the resolutions, bitrates and framerates for video. I hardly doubt it will be possible to go beyond what's defined for AVCHD.
And how specification is related to this?
You could have some problems with programs not supporting some framerates, but universal players and converters must work fine.
Looking good! Nice and clean design.
Also, back in the days this was true, but since AVCHD is digital, doesn't this make the 'definitions' changeable? I mean, you can't change the resolution of a miniDV tape, but this is digital, so at least framerate should be possible. Especially considering the first sample shots as said before were 24p.
Thank you for your work tester13. I hope you soon get the camera.
Here is a short wish-list to improve the usability of GH1. These patches would decrease the number of possible errors that normal people do (such as I, at least).
1) When switching to the manual movie mode, the aperture value should be the default value to be changed with the front wheel (not the exposure time). Alternatively, the camera could memorize the aperture/exp.time selection, while visiting other than manual modes.
2) When switching to the full automatic mode and the focus switch is MF, the focus mode should be automatically switched to AFS or AFC
3) In movie mode, the movie-button in the upper right corner should only stop the move, not to start it.
Justifications follow:
1) I always shoot movie in 180 degrees mode, that is, the exposure time is fixed, and I control the exposure with the aperture. Between the movie clips I also take pictures, usually in the full automatic mode. When switching back to the manual movie mode, and turn the front wheel, the exposure time will be adjusted. I need to click the front wheel before I can change the aperture. This is annoying, since I need to be aware if the aperture or the exp.time is active. If I take pictures in manual mode and switch back to the movie mode I do NOT need the click the wheel first to set the aperture.
2) How many of you have got unfocused pictures, since you have forgotten the focus switch to the MF mode? It is possible to have the camera at full automatic mode with MF. There is a completely useless short, tiny warning in the bottom right in the viewfinder. How many of you seriously use full automatic mode and manual focus? Panasonic has allowed this combination, and I do not understand why. The camera is capable of overriding the focus switch setting, it does this with the 20mm pancake lens: when I swith to AFC, the camera switches automatically of AFS. Similar could be made to the full automatic mode and MF.
3) How many of you have noticed that the video clips contain shots between the intended clips and the intended clips are missing? There are many situations when you cannot see from the camera if it is recording or not. There is no external light showing that neither. For us who record always in movie mode, there are two buttons available for controlling the movie start/stop. It is possible now to dedicate one button for "start movie" and another for "stop movie". It is enough if one of the buttons is only "stop movie": then you just push it once before starting the movie with the other button. In debugging this, the pancake lens warning text "SWITCH TO AFS" would be useful.
MiniDV is as digital as AVCHD. It's just a different way of storing the data (file system vs. binary stream on a tape). And true 24p is already covered by the AVCHD spec.
Ok, as long as you don't expect any of the BD/AVCHD-players to play the content you might be right. If you succeed in changing the bitstream to some resolution or frame rate not supported by the AVCHD spec you might still be able to convert the video streams with ffmpeg or some other tool which operates on the transport stream level.
its not the real signal but an up-sampled version of the 800px vga-like frame buffer fed to HDMI which negitiates at 1080 or 720, so most likely no realtime AVCHD to HDMI processing and no fast chipset direct high bandwidth data-path exists - only subset proxy to videoram/framebuffer.
So, it is just upsampled version of picture of viewfinder resolution (800x600)?
A backend for GCC is not a trivial task, if you could write MN103S code in c++, what would be the advantage over assembly language?
According to the gcc supported processor list the mn103 aka am30 is supported. The is also mention of a simulator.
Part of the gcc setup is bintools which includes the linker and assembler. You can always use the assembler if you want. But it is not a very human friendly assembler. There is no point to g++ over gcc in this situation as you don't know the API to the executive or other library functions.
Development screenshot of v3.00:
As you can see, now you can have patch that allows you to enter increment or direct value input.
So, later you could specify required framerate yourself and experiment with bitrate settings.
It is still in development and it'll take some time to be complete, test and add some very interesting patches to the list.
It's important to find a way to defeat the version check, so that testers can go back to genuine firmware for warranty purposes.
We'll add patch for this later.
As it requires complete understanding of this checks and carefully planning.
One error and you won't be able to update again.
It is very crucial patch.
But I have very interesting thoughts about it.
Version check.
Looks like Panasonic is one of the few, maybe even the only one, manufacturer allowing downgrades for firmware, meaning you can go back from 1.3 to 1.2.
I tested this on the LX3 and ZS3. Should work the same way with GH1.
This means if the beta versions are set to be 1.5 one will always be able to go back to 1.2.
Good luck.
Version check.
Good luck.
It must be checked for GH1.
I hope someone can check if he could go back from our custom 1.23 back to 1.22.
I have the GH1 with the latest 1.21 firmaware. I just downloaded the previous version that does not check for Panasonic batteries. But it also has version 1.21. So how can I prove to you that going backwards works on the GH1?
If it allow you to update, it is prove, as latest is actually 1.22.
And one without battery check is 1.21 :-)
Seems like the camera ignores it. I have 1.22 installed and have a copy of version 1.12. I put 1.12 on the SD card and I don't get any message when trying to update. I tried with full battery and using AC power. :(
update: I also tried simply renaming GH1__112.bin to GH1__123.bin and still doesn't work.
hmmm, forget payday, just donated, have to agree with FW downgrade, must always be an option, dunno if panasonic has any countersteps (either already built in or via FW upgrade) to prevent us from going back. otherwise, the following "features" would be great (and i hope/guess doable HW wise):
- get rid of the 30 min limit
- 1080/24p
- shutter speed while recording to something related (current FW i.e. has some limits, i think its 1/50 min even for NTSC). for recording 24p options should be 1/24, 1/48, ... can anybody sum up the current limits of shutter speed for NTSC at the moment while recording? i'll do the same for PAL.
- set data rate a bit higher if not an HW restriction (even if it could mean risk of overheating when operated for longer periods of time)
Are you sure it was 1.12? Where did you get it from?
I would like to give it a shot. Where did you get 1.22 from?
