John Godden
Really? Then why did the GH4 give a "insufficient writing speed" error? Extreme Pro 95MB/s class 10 U1 would be a better choice for non U3 SD card, but if you think it's fine go for it.
^^^^^^ What Erik wrote !
Yes, recording is interrupted and you get a message "recording stopped due to insufficient card write speed" or something like that. I was spooked after it happened to me so I bit the bullet and ordered a 32 GB SanDisk U3 card for $129.00 from B&H. It might be overkill, but after spending a lot of money to travel to photo shoots I just can't afford a recording stoppage or write error and SanDisk cards have never failed me plus they are highly regarded by some pro photographers who use their cameras so often they sometimes wear out the camera bodies before their SD cards!Just out of curiosity, if you put in a card that is too slow, does the camera just stop recording? Does it give an error message?
Good to know the Transcend 128GB U3 cards are solid. I thought the larger capacity cards were a problem with the GH4.I purchased the Transcend 128GB U3 card because it's the only way I can record more than 2 continuous hours in 4K resolution. I've used it on several gigs now, and so far, so good. I haven't tried the 200Mbps HD mode, though, but 4K works like a champ. Just a few days ago I purchased another one of the Transcend cards. YMMV.
Yeah. The Transcend 128GB cards give me around 2hrs 45min non-stop recording in Cinema 4K. Very happy about that, especially considering the price of those cards.Good to know the Transcend 128GB U3 cards are solid. I thought the larger capacity cards were a problem with the GH4.
I use UHS1. http://www.amazon.com/Extreme-SDSDXPA-064G-A75-Digital-Extended-Capacity/dp/B005VDRD4C
That is correct. UHS1 and it works perfect. The writing speed of the card is 95mbs. The 4K recording speed of GH4 is 100mbs. So yeah. I even tried the 200mbs HD and it worked flawlessy.
I purchased two of these...
http://www.newegg.com/Product/Produ...cm_re=sdxc_sandisk_pro-_-20-171-941-_-Product
Yes, they're UH1/Class 10, but the max read/write speed is the same as UH3 Transcends. I get that that isn't the minimum speed, but 200mbs = 20Mbs, so if it can handle bursts up to 90Mbs, I'm willing to bet sustained 20Mbs isn't going to be a problem (and I wouldn't shoot anything at that speed anyways that wouldn't allow a second take).
Anyways, planted the GH4 in front of the TV, set it to 1080p/60 in 200mbs, and began recording the Hobbit and Transformers 2 off the screen. Figured that's a lot better than static shots, with plenty of screen changes from things blowing up. I'm on my fourth time through the first card, and no issues. I'll probably do it about a dozen times to each card just to make sure, but I think these Sandisk cards are safe.
