Not necessarily. Spatial offset works. And the JVC is using CCD chips, not CMOS, so it will have a big difference in performance from the EX1 regardless.So if Barry is correct, it's worse than what Kenn has posted. Okay, so without knowing exactly what pixel-shift means or involves, it's basically means it's not as good as a true 1080p as the EX1 is, correct?
Yes, that's what that should mean. The HD200 had it, and the new HPX300 has it. There's LCD flip, and then there's actual image inversion, and the HD200/HPX300 have the "good kind", the actual image inversion.The camera features an "image flip" function that corrects for the inverted image produced by prime lenses.
Is that mean I can use a 33mm adapter without flipping since the camera as a built-in image flip functionality?
I am unaware of any 1280x720 1/3" progressive chip that can do full 60p, so I suspect that this is more along the lines of the Sony V1U, which was introduced as having "1920x1080 sensors" but in reality had 960x1080 with diamond-shaped spatial offset and interpolation. As far as I know it's not possible to do 1280x720x60p at the 1/3" size.
This is what I was told by JVC representatives and they confirmed the technical specs of my article the day it was published. I assume they are using the same technique as with the the HD100/200 series cameras by combining two 640x720 chips x RGB and reading out to two image processors. This design caused some "split-screen" issues for both Barry and I back when the original HD100 was released (2005) but JVC seems to have worked out how to maintain calibration.If that's what they told Tim, then that's what they told him. The only way he would have of knowing this is if someone at JVC told him, because the specifications aren't published anywhere.
I am unaware of anyone who's made anything approaching a 1280x720x60p CCD at 1/3". JVC's initial approach was two stitched-together smaller CCDs. Sony's and Canon's approach were interlaced chips. And Panasonic went with 960x540x60p progressive. In order to get 1280x720 progressive CCDs they'd have to double the readout of anything that's been done before. Have they? May very well be. But if they have, it's unprecedented and a massive breakthrough.
JVC doesn't publish the spec for pixels. I'll have to ask Tim who told him they were actual 1280x720 chips.
If it's two chips then that makes more sense and I can see that. It will be most interesting to see the results; this is definitely a unique approach. JVC has always been a very innovative company.This is what I was told by JVC representatives and they confirmed the technical specs of my article the day it was published. I assume they are using the same technique as with the the HD100/200 series cameras by combining two 640x720 chips x RGB and reading out to two image processors. This design caused some "split-screen" issues for both Barry and I back when the original HD100 was released (2005) but JVC seems to have worked out how to maintain calibration.
Is anyone running tests on this camera? I'm personally interested for 2 reasons:
it's quicktime .mov file abilities and the fact it still has CCD chips.:beer:
Bill
