How do you install them on your camera?
mac or pc? You need to set the camera to usb or fire wire HOST. Then when in vtr mode hold down the button untill it becomes a big usb/firewire drive. Pc doesn't work well with fire wire so use usb
Which editing application are you using?
Thanks mikko, should I just go straight into the external hard drive, would that be easier? .Make sure you are updated to Premiere CS 3.1
"USB Host" is for offloading from the camera directly to an external drive - not what you want here.
"USB Device" is used to turn the camera into a basically a "USB P2 Card Reader". I don't recall if you need a driver for the HVX200 or not.
- Mikko
What did you use to import your footage?i just received my e -series 32gb card. i took it out the package and fired it up. no problems on my older hvx200.
