Barry_Green
Moderator
-7 = no edge enhancement.
-6 = a little tiny bit of enhancement
-5 = a little tiny bit more
etc.
etc.
With the stock lens then, would turning the detail "off" (-7) help to give a shallower depth of field?-7 = no edge enhancement.
etc.
In short, No. The detail/edge enhancement only affects portions of the image that are in focus, it has no effect on something that's out of focus. So, in a way, the opposite would be true -- setting the detail level higher may slightly accentuate the perception of shallower depth of field, because the in-focus portions would look even sharper (through artificial edge enhancement) whereas the out-of-focus portions would be just as out-of-focus as always.With the stock lens then, would turning the detail "off" (-7) help to give a shallower depth of field?
In other words, when the detail enhancement is "on" does it cause the camera to digitally focus on areas that would otherwise be out of focus?
Does detail reduce the bokeh? Or does it somehow enhance the bokeh?
I....................
Let me put it like this: Light --> Lens --> CCD --> Digital RAW Footage --> Applying all File-Settings+WB --> DV Format --> Tape.................
What I want to say here: "If we know that we have to apply the digital enhancements sooner or later then I suggest sooner is better !"
What do you guys say ?
I'm really confused after listening to my own understandings of DVX100B and comparing it with big-guns like Barry etc.
If my understanding is correct about the footage acquiring process then I would always go with In-Camera. As everything which is set to change the composition of a footage is applied on the RAW/Uncompressed footage rather than compressed footage.
Now, if that's happened then its the biggest advantage to get your composition right in the first-place i.e. In Camera and avoid post processing as much as possible.
Even if there is no-detail what-so-ever and with the most neutralized settings to get just the right exposure; processing in post means we are applying digital artifacts on an already handicapped (4:1:1 color sampled DV) footage.
Finding little gems like these is what keeps me coming back. I have come across similar comments from Barry on this subject before but sometimes the same message stated in a different way really helps to turn the lights on.I don't disagree ......
There's another point, though. Edge enhancement creates a much more complex image due to the localized contrast enhancements everywhere, thus much harder for the DV codec to encode. DETAIL down creates a smoother simpler image that compresses much better, and therefore looks better most of the time. If in doubt, shoot something (anything) with DETAIL at 0, and then check out the individual color channels to really see the all the damage done by sharpening, color subsampling, and compression.
