D90 Stair-Stepping Removal
Thank you
Thank you
Thank you guys for the tons of good info, the wonderfull stairstepping removal, works like a charm.
This is my first movie I ever made, aside from some editing on some video game footage but I like it, I barely took any pictures with the D90 since I got it yesterday and I'm more pleased with the dmovie thing than with the other features it has over my old D50.
http://vimeo.com/5453573
Hi,
thanks to the extremely useful information on this forum, thanks to Lee Wilson for his work and all posters.
I want to further work on the userfriendliness of the proposed measures:
- creating a vbs-script (like the python-script, which is not working for me) which should work for most people to automatically creating avs.-Files
- enhancing the avisynth script with save as "motion jpeg" and "dvx or xvid"
Please join me in creating this. Any help is very much appreciated. I am currently working on the first solution. Does anyone know how to do the second solution (my internet search was not successful)?
Kind regards,
Peter
for the latter just use any batch processing software and add all the generated script files. the beauty of avisynth is that you don't even have to save, the script itself is a playable avi file.
you've missed the point. the upscaler scales the image to 1280x801, then optionally up to 1080p. if you scale it to 1080p first then down again all you "gain" is a lost generation and lower end quality.
well i actually only dropped the edited 720p sequence into a 1080p timeline....then applied the upscaler....then exported as 1423x801....
Even worse since that scales the image first to 801, then down to 720, then up to 1080 then down again. :-) follow the directions and you'll see much better results.
warp sharpening has been mentioned here a few times as a way of fixing the soft detail and blurred edges of d90 video, so i thought i should develop a final cut plugin that does it. it's now finished and part of my free plugins pack along with the d90 rescaler and upscaler. give it a try. setting the amount to 1 works well for "rescaled" footage, while 2 works better for "upscaled". have fun.
http://www.mattias.nu/plugins/
/m
I just applied the displacement map technique to d5000 footage. Improves the image a lot.
Great job to those people who did this and shared to all.
Hey guys! Use somebody Nuke for stair step removing? Couse i can' import the avi. I get this error: Unable to decompress video stream.
Somebody talk about Nuke script, eand i don't know that how they import the raw avi. Or they just convert it before imbort!? :S
dividing by 1.113281 results in the exact same pattern of 8's and 9's as the table i use in my plugin so i'm not sure what they mean by other methods doing it wrong. i'm open for suggestions as to how i can improve the fcp plugins though, and there's indeed a difference at the edges between lee's table that i'm using and the one you get from division. i tried the formula though and that gives the wrong result so i'd be happy to know where the error supposedly is and if there's an end condition needed. i've not been able to eyeball any fault in my table either...
actually i downloaded it now and they have the *exact* same sequence, so if you think this is the first method that gets it right you haven't tried many methods. :-)
Hi there,
Hi Lee, hi nihilus,
Thanks for this thread! I've registered here because of it.
I've written a filter for frei0r removing the stairs, based on the posts here. Unlike most versions here it does not scale the image though but directly transforms the image (similar to Halsu's displacement map).
The plugin is on my frei0r fork at the moment, so it needs to be compiled, but I will try to get it into the original frei0r codebase.
Now where can the plugin be used? In all apps that use frei0r, listed here:
http://en.wikipedia.org/wiki/Frei0r
Personally, I'm using kdenlive. The filter can then just be applied :)
Here an example; upper part with filter, lower part without. Zoom 200 %.
And a «real life» example image:
after applying the filter:
Granjow
Hello, i spent all the weekend reading all the stuff here and try to improve the quality of a video that i have made with d90. but in fcp or with ae the result is the same. i don't know what i'm doing wrong. i would appreciate a little help :S thanks
i can upload some clips from the original file http://www.youtube.com/watch?v=LYSsCnfRMb0
you're not saying what you're doing so it's hard to say what you're doing wrong but my guess is you're simply not looking close enough, it's not like the dirrerence is striking if you're not sure what to look for.
