Lee Wilson
I posted this in the "D90 D-Movie quality is really, really bad!" thread - but figured some people might not search there looking for a solution to the D90's 'stair stepping' problem . . . .
Anyhow, the problem can be removed fairly successfully (depending on the source footage I expect) using a simple to apply 'post' technique.
Here is a quick test of the technique.
http://www.vimeo.com/1935644
It is best to download the original file from Vimeo and view the file at 720p.
If I get a chance today and there is enough interest I will post a detailed explanation of the technique, but basically I am slicing the footage into 9 pixel high sections (actually the 'binning' method Nikon use kind of goes 9 - 9 - 9 - 9 - 8 - 9 and so on - or something like that) - I then moved these slices apart by 1 pixel and filled the gap by interpolation.
This results in a slightly taller frame which then needs to be scaled back to the correct height (around 90%).
You don't need to do this for every clip of course ! once you have set up this file (30 minutes work at most) you can use the same file with its masks to fix any clip you want to put through this fixing process.
I used After Effects but the same method can be used in any kind of software that allows basic stuff like masks and the ability to layer clips and set opacity - so things like Final Cut, Shake and Premiere etc etc.
Like I said if you want a step by step explanation just ask.
Lee
Lee
