Apefos Adapter
OlegKalyan, sad to read that, but it seems the Flaat and Lpowell profiles can do the same or better.
Actually, the level marked 100 in Color Finesse's Luma Waveform is neither 235 nor 255, it's 1.0. As explained to me by the developer of Color Finesse, no 8-bit values are used in 32-bit After Effects, everything is calculated in floating point.I'm not disputing anything that you just wrote. But what I am saying is that 100 IRE is 235, not 255 in the Color Finesse screen capture that you posted... Just display a clipped Y WFM in Color Finesse and then display a YC WFM in Color Finesse and you will see that the YC WFM has excursions probably to 110 IRE. I simply don't is how 110 IRE is possible if 100 IRE is 255.
I saw that. What's up with the weird dirty screen? Is that the way the Ninja records?
I don't know but that video is a waste of time.
When you select a 32-bit full-range Rec. 709 working space in After Effects, it converts the H.264 0-255 YCC values into floating point RGB values scaled from 0-1.0. Color Finesse has no knowledge of your working color space, it simply calculates the equivalent luma levels from the floating point RGB values, labels 1.0 as 100, and clips anything larger than that. In 32-bit mode, After Effects can seamlessly handle superwhites and superblacks as values that happen to fall outside the 0-1.0 RGB range, but it doesn't destructively clip them until you export the footage into an external video format. As a result, graded footage may contain superblack values lower than 0.0 and superwhite values higher than 1.0.
Similarly, Color Finesse's YC Waveform chart isn't an actual waveform, it's a calculated simulation of what you'd get if the digital RGB data were converted into an analog video waveform. In this case, Color Finesse shows you how the simulated luma and chroma signals would combine and whether they would fit into the broadcast legal limits. Since the YC output signal is defined specifically in NTSC terms, the scaling used in this chart actually is the analog IRE scale. The 0-100 scale used in Color Finesse's Luma chart isn't necessarily an IRE scale, it's actually just a scale of floating point percentages. It will match the IRE scale only when you select a broadcast studio-swing profile as your working color space. This is an example of the kind of behind-the-scenes data juggling that modern video editors use to finesse the discrepancies between different color spaces.
BTW, I'd love to post some footage I shot today, but I don't quite get permission to do so. All I can say I'm blown away by the quality of this plasticy camera. It looks so much better than any previous DSLR.
I know this is a stupid post without footage, but I had to say it.
I would expect the BMC to be better than this, but I have no idea really. It's exactly like the D800, so if you find a D800 vs BMC dynamic range comparision, you'll have your answer.
D800e still better a bit, imho, more so withough mosaic filter, with significantly better resolution, with it just slightly better resolution.
Range slight advantage to D800e.
it's commonly known from BBC tests by Alan Roberts that latitude of D800 around 12 stops, D4 around 13, recording to card.
So how many stops have you measured for flaat 10 and 12?
