BobbyMurcerFan
squig, does this camera record true 24.000 or 23.978 when recording 24P? I ask b/c the 720P mp4 file is 24.000.
Thanks again!
Thanks again!
Thanks again!
Can you post one original source clip, i.e. one take? Thanks for considering this.
But that's exactly one of the things I want to test most, the color range used by the native recording. So please...![]()
That's awesome, thnx Squig. I've been playing with some Linear2Log conversion and is pretty amazing how much you can recover. Also, res can hadle moderate sharpness quite well beyond any GH2 footage IMHO
2. The camera internally records video 16 to 235. This is good in that it keeps NLE's from clipping "illegal" levels. This is not so good in that it does remove gradations from the aleady limited 8-bit recording levels.
P.S. Did you get the kit lens? And if so, what do you think of it?
Not according to Adobe After Effects and Nikon. As with Canon DSLR videos, the H.264 MOV files are tagged with metadata flags that indicate they contain full-range 0-255 Rec. 709 video streams. I can also see the full-range luma excursion in After Effects, and manipulation of the gamma curves confirms their full-range nature.The camera internally records video 16 to 235. This is good in that it keeps NLE's from clipping "illegal" levels. This is not so good in that it does remove gradations from the aleady limited 8-bit recording levels.
When you decode or transcode the original video stream into another format, the video editor and/or codec may convert the data into broadcast 16-235 range, and may do so behind the scenes without notifying you. The only way to know for sure is to analyze the original H.264 file.
Here are links to new test with Flaat11, I had to open up half a stop on GH2 to match exposure,
http://yadi.sk/d/kprDlbBt31RYk
http://yadi.sk/d/vjONtqku31Rfo
Nostalgic all -2 on GH2, Flaat11 on Nikon, not changed.
focus on letters on the box.
