Ok, let's try this again.
My purchase:
1 AB1600 (640ws)
1 AB800 (400ws)
1 PCB Large Octodome
1 Vagabond mini DC pack
1 Spare battery for Vagabond mini
1 Pocketwizard MultiMax
2 Pocketward Flextt5
I already have stands, cases, umbrellas, etc. from my film work.
When I compared costs on Elinchrom, Profoto, AB, and some others, getting a mobile kit put together was SIGNIFICANTLY cheaper going with the ABs.
AB800 is 320w.
I'm not counting the Vagabond here because it's the cheapest portable power and you can use that with most lights available.
1 AB1600 (640ws)
1 AB800 (400ws)
So cost for these are 1570$ + battery.
2 Elinchrom BXRi 500w
1 Elinchrom Skyport SPEED Transmitter
1 Visico 120cm Octabox
1540$ + battery. Where's the 2k$ difference? 50$ more and you get softboxes, stands and cases worth 650$ that you can sell and get at least 500$ from them that brings the price to 1040$.
Huge bonus (additional to the ones mentioned before) with Elinchrom setup is that with Elinchrom SPEED Transmitter you can change the power of the lights on your camera from your transmitter.
In jambredz case he should obviously buy the set since he saves 650$ by doing that. Though, I would not suggest to get the D-Lite it 400/400w set or BXRi 500/500w set if you don't always shoot in daylight because in studio these lights are too powerful. D-Lite it 200/400w and BXRi 250/500w sets are way better choises because the smaller light will give you smaller minimal power so there will be less cases where the lights produce too much power. In more cases the problem is that lights produce too much power, not that they produce too little.
I read all kinds of stuff about color shifting at lower power, etc. Whatever. In general I will be out on the beach shooting bikini models, so I'll be using full power.
And DSLR's have annoying rolling shutter, jello, etc. whatever. You can fix it on post.
You said you are able to shoot 1/250 with your bees, but lights have nothing to do with that. You are able to shoot 1/250 with any lights if your camera's sync speed is 1/250 and if you use Pocketwizards. With Elinchrom you don't need expensive Pocketwizards. Elinchroms built in triggers are even better since you can dial the flash power from the transmitter.My cameras all sync at 1/250. Pocketwizards support that just fine. I don't know why you are talking about cheap triggers.
Like I said. If the Elinchrom's are working for you, that's great. The Bees are doing what I need them to do, and I am happy with them. So why the need to put down other people's gear?
As I've mentioned, I am VERY new to strobing. I've been a sports photographer since before most people on this list were born. But this is all new to me. I've surveyed what I wanted and needed, found a solution that works for "ME", and am happy with it.
Is that ok with you?
Read below...
Exactly. Use what works for you and be done with it. Somebody always has to jump in with "my stuff is better than your stuff drama..."
Well I think it's stupid to pay more for worse equipment and that's what you are suggesting here with your made up cost differences. People should be suggesting the best option, not the equipment they own. That is the universal bad when it comes to suggesting equipment, people usually suggest what they own, not what would be the best option.
