Which model? It'll help to know which 13" Trinitron, as you need to have a "blue only" feature.
Also, this requires a reliable color bar feed, which the 5D and 60D cannot do. And you have to be careful with color bars sourced from NLEs, or downloaded from the 'Net. Not sure if they ever rectified it, but for the first several versions FCP's color bars weren't accurate.
Basically, you center your contrast setting and turn on the blue-only (aka "blue gun"). Then adjust your Chroma until the bars on the left (white) and right (blue) each have no discernible difference with the small rectangles (blue under the white and vice versa) underneath. Last, adjust the Phase until you get the same effect with the bars to the left of center (cyan over magenta) and right of center (magenta over cyan).
It was my plan to download a jpeg of bars from the net and use on my 60D, although I also have an HVX and I think (have to check) I can output bars from there.
What is the alternate way to color calibrate if your field monitor DOES NOT have a blue only setting? I have a 668gl Lilliput monitor that I need help calibrating, but it does NOT have a blue only setting.
