Ike615
I'm having the same problems as you SurJones, with the interlacing line problem, but when I looked at your screen grab I saw a window that I've never really payed attention to (the last inspector window on the right). So I did a little messing around with it. I've found that if you put the output field to "same as source" or "progressive" that it completely takes away all the Interlacing lines. I'm very happy about this find because this problem has been annoying me for a very long time. I hope this helps you as well. Now I need to learn what the other controls do in that window and if they're worth the added compression time.
