Baby F3 aka NXCAM S35
I understand where you're coming from Gabrobot, but the truth is - I've very rarely run into macroblocking with xdcam ex. When I did, it was such extreme movement I don't see how stuff like that would ever be acceptable in a serious film anyhow. As duke also pointed out, since the f3 is so much more noiseless, there is less, and in some cases, zero noise to push and strain the codec, leaving 100% of it's power to encode the image.
Nobody's arguing that their aren't huge advantages to offboard recording - their are. I'm just saying you don't absolutely have to. You'll still get hugely gorgeous images that will be able to be screened, projected, and graded. And in 90% of cases, you won't be able to tell whether the source was onboard or off. I'd be willing to make a bet on that, and am even willing to post up some comparisons. We need to also keep in mind film moves. About 24 times a second, usually. Your persistence of vision uses that to its advantage, combining details from every frame into one very detailed image. This is why when you pause, blow up, and study one frame, of course you're going to see compression artifacts. But how often do you see compression artifacts (from professional codecs) when watching them back for review? Do you remember the last time you saw and complained about compression artifacts when watching a bluray? Never, I'm guessing. Even though the bluray spec hovers around 25-30mbps 4:2:0, with a lot of discs still using mpg2. That being said, I'm sure almost everyone with an f3 will eventually be picking up a recorder, I know I will be. (unless I end up getting the baby f3 nxcam, let's hope to god it has 10-bit output)
Fair enough, like I said it seems like having both options is a good way to go.
I personally would have trouble only shooting to XDCAM with such a great imager...I regularly edit EX1 footage together with HPX370 footage, and grading the 370 with its intra frame 10bit codec is just incomparable to the EX1. That said, the EX1 is a fine camera and it fits right in for the purpose its needed for. But for personal projects I always pick the 370 because I tend to use high shutter speeds (less motion blur for codec smear to hide behind) and do heavy grading.
It's funny, names get recycled. Remember the Sony PD150 and PD170 and DSR200 and DSR300 and DSR500? Now we have the Panasonic HMC150 and HPX170 and HVX200 and HPX300 and HPX500...
what´s funny is filmmakers do the same thing with films ...about every ten years ....esp with teen flicks
I have to agree with fohdeesha on this one and wonder where avro is coming from.
I shoot with a nano on an EX1 all the time. XDCAM footage has it faults, but mostly in extreme situations. In 80-90% of shooting situations the codec looks great and you'd never notice the difference.
The EX weaknesses are:
  • During extreme movement. Enough moving leaves, waves, etc and 35Mbps isn't enough. The F3 being less noisy that may be less of an issue.
  • During green screen, 4.2.0 allows a color error up to 3 pixels off, while 4.2.2 you're a max of only 1 pixel off.
  • During extreme color grading. Flame me for it, but if you are doing extreme color grading on an EX you don't know how to use the camera. Get close to what you want in picture profiles and you don't have an issue no matter what look you're going for. 10bit can save your ass if you've gotten sloppy.
That being said, most looks come out fine being graded in 4.2.0. And not just for web use, but all use. I'm using both types of clips on my feature and they look brilliant on both a big screen TV and projected. You didn't see anything wrong in the car interiors in Public Enemies with Johnny Depp did you? How about This is It with Michael Jackson? Sure they massaged the images, you plan on tweaking your images too don't you?
For a drama, an interview or anything ordinary you can intercut the footage without noticing it on any size screen. There is a reason that 4.2.0 was first used, the human eye doesn't notice it.
All cameras have their faults, I don't care if its a Red, Panny, Canon or Sony, its up to the operator to know and plan around those faults.
That being said a Nano set to a time code trigger has many advantages like back up recording, more audio tracks, no compression artifacts, etc plus you almost don't notice its there. I'm sure the Ki Pro Mini has advantages too. Things like hyper-gammas should make it even better. So while I would recommend an recorder, you're not horribly crippled without it.
Look,
if you upgrade from Z1 and HDV it is good ...
But I see EX results every week. We produce lots of shows recorded for Foxtel on XDCAM hd, EX and HDV...
You notice bad results with EX1 and EX3 especially when there is PAN movement or other shots when there is lots of Action.
Editing from XDCAM hd and HDCAM is far more stable.
Now if You do not notice these things then it is OK for You .
Why do you bother about F3, just get something cheaper and You will be fine.
I on the other hand can not use EX1 and EX3(which i owned for 1 month)....i just do not like the LOOK.
I get far more pleasant images from Pana 500 or good old 900 or Canons or AF100 etc..
Sorry for being "upfront" about it.
Take Care
jiri
Look,
Take Care
jiri
This is a lot different than"worst codec on the planet!" and calling fohdeesha's statements crap. Just saying....
Look,
Take Care
jiri
The first exception that I mentioned is extreme movement. In a pan everything is moving. Pan too fast and it blurs. No question. Thats when a Nano is handy.
I'm just saying that doesn't make it the worst codec on the planet.
It's so painful to read this thread! Damn my NDA! Damn it.
March 23rd is right around the corner.
Oh Andy, how about you and I have a few drinks down at the pub, I'm sure you have some wonderful stories about the camera you can tell, once the alcohol hits haha. I'm sure the camera is going to be a hit no matter what, specially at the price point its set at. I'm in love with my F3, but would love to see this little fella be a B cam if necessary.
For those that don't speak German, the Google Translator version of the text between the YouTube videos.
"Sony news of the Creatology Roadshow
As part of the current road show in Germany Sony shows new S35-sector, but also for monitors and audio equipment."
"Sony is currently conducting a road show under the title "Creatology by" and shows in four German cities, current and future products and technologies. It all started in Munich, it will follow Berlin, Hamburg and Cologne. film-tv-video.de attended the event in Munich and summarizes some of the highlights in the video below. Sony employees to present: the future NXCAM Camcorder with S35 Sensor, SR memory and the portable recorder for the PMW-F3, new LCD and OLED displays, as well as a portable audio recorder."
"Sebastian Leske, Gisbert "Most high belt from Sony and Mark presented by HL audio latest Sony innovations: the compact NXCAM Camcorder with S35 Sensor, SR memory and the portable recorder for the PMW-F3, new LCD and OLED displays and a portable audio recorder.
Sony has also reorganized in Europe in recent months and given a new structure. When the road show by the way it goes so well about the customers and sales partners to explain this new structure. In the following, the second video explaining Goran Hantschel, Commercial Director, Professional, and Claus Pfeifer, Strategic Marketing Live Production, what it's all about and what the reorganization for customers."
"Goran Hantschel and Claus Pfeifer explained by Sony at the first station of the Sony-Creatology tour in Munich, as Sony has reorganized and realigned in Europe.
In addition to those shown in this message is waiting for the product exhibition road show also with lectures, seminars and case studies."
Hey it is Google Translator... It ain't perfect.
yeh, that´s definitely positive frustration ! Well imho who cares about contracts anymore anyway ....go ahead and spill the beans .....we won´t tell !!
Jiri,
The F3 footage posted around looks better than most Red One footage. So I don't see what you're talking about about a cheaper camera doing the same as the F3, unless you've seen NXCAM S35 footage and you're not telling us.
