Andrew Stone
Avro, the external recorder has a place so it can be mounted on 15mm rails. It is intended to mount behind the camera on rails unless the operator deems otherwise. The only point on the camera that Sony earmarks for external mounting points for accessories, from what I gather, is the metal reinforced threaded hole towards the back of the handle, in other words the 3rd one back. The holes on the top of the body that flank either side of the handle don't seem to follow camera convention. The ones on the handle apparently do but they don't have the reinforcement that the rear one do and the handle with those holes would normally be used for a lowmode Steadicam mount but the shoe at the front and the viewfinder are in the way so it renders it useless from that perspective. All seems rather spurious.
