I don't record audio much with my camera. I will have to soon.
I have an XLR microphone that I used with my HMC150. Can I just get an XLR to 3.5mm adapter and use that microphone with my T3i?
Will that work?
Thank you.
+1 to that!Your best bet if you don't have a lot of cash: use the 150 as your audio recorder. You'll get far better audio. Record with the Canon's mic and use it to synch.
I actually borrowed a 3.5mm mic to test it out...can anyone confirm that the mic records to the left channel and the built-in mic records to the right channel?
Is there anyway to turn off the built-in mic if I wanted to?
Thank you.
Hmm, I guess I'm confused because I don't have an audio tab. I definitely went through all of them that's why I didn't see anything about audio..maybe I'm missing something...
I just installed it 2 weeks ago so I'm assuming the latest version. If I press the menu button, I get 12 tabs..by default only 6. The first tab is LiveV.
I had audio disabled because I shoot with the 2.0 bitrate (Alex recommends disabling audio) so for a second I thought that's why I wasn't getting the audio tab...but yea, I still don't see any tab called 'Audio'.
Tabs I have:
liveV
expo
movie
shoot
focus
display
tweaks
play
config
power
debug
help
