Samurai does pull-down, Ninja doesn't. If you remove the pull-down in post you'll still get the massive quality benefit, longer record times, 10 bit, 4:2:2, cheaper storage etc.
Dave Shapton
Atomos
This is where the confusion is lying. In a previous post, you mentioned that if you shoot progressive, there would be no need to deinterlace. For me, this extra step is way too much effort. I'm hoping that a future firmware can recognize the 24p flags in the HDMI stream to actually only record 24 progressive frames.
It's a confusing subject - especially if you're on the PAL side of the Pond, where it's always been a lot simpler (but we had colour TV 10 years later than in the US, and we can't even spell "colour").
I'll try to explain. What I said in an earlier post was that if you shoot in 24 frames per second progressive there would be no need for de-interlace.
If your camera outputs a TRUE 24p (ie 24 progressive frames, with no pulldown) then the Ninja records that. If your camera outputs a 60i signal with a 24p signal embedded via pulldown, the Ninja does not have the capability to remove the pulldown. This is an actual hardware difference between the Ninja and then Samurai - the Samurai does have the additional hardware resources required to do this. It's WAY more than just recognizing a flag - you have to actually process the video to do this in real-time. That's why it can be quite slow in software.
I hope this helps.
Dave Shapton
Atomos
Hi Dave. Let me start by saying that it's awesome that you are here to answer our questions! We all know that the AF100 is able to record at true 24p. I'm just confused as to what happens to that signal coming through HDMI? I guess the bottom line question is, when using the AF100, are you able to record direct to disk, a ProRes mov file that is 24fps, when recording 1080p24 without having to do a pulldown removal?
Well, can I just say that I think it's awesome that people are on here asking questions in the first place!
As far as 24p is concerned, I was talking in general terms - not about the AF100, because it does seem to have some characteristics that apply to that camera only.
We are getting reports in from users about this and the 101, but we're getting a mixed message. Some say it works, others say it "sort of" works, and others say it doesn't really work at all. We need to get more data in to be able to discern a pattern here. What we might be seeing is a difference between American and European models.
Meanwhile, we're getting great results with "true" video cameras and we all know about the issues with DSLRs in general. We're all going to NAB, so that will be a good time to get as much information as possible about all of this, and we'll report back if we do.
Dave Shapton
Atomos
"true" video recorder.
Well, please keep in mind that technically ProRes is as multi-platform as Cineform is. Apple does make a free downloadable decompresser for Windows.I would have thought something like Cineform would have been chosen as its multi-platform.
For AF100 users, I would seriously say skip the Ninja and wait for the Samurai. Just my opinion only and I'm sure Dave will weigh in with Atomos' official stance, but -- I've got a Nano (which has both HDMI and HD-SDI inputs), and there is no force on earth that could get me to use it in HDMI mode instead of HD-SDI. HD-SDI is just -- well, it's the way it should be done. Everything about the HD-SDI standard is better, everything about HDMI is worse. The connector is worse, there's no timecode, and (as already said) there's no 24PsF. The AF100 has the ability to output 24PsF and the Samurai will (if I'm reading Dave correctly) be able to record it directly, as 24p, no pulldown.I think many really just want the Ninja to be the amazing recorder that it appears to be.
The Ninja would be viable for HDMI-only cameras, such as the Sony FS100. But if you've got access to HD-SDI, by all means, step up to the Samurai (or Nano or Ki Pro Mini or Gemini or whatever HD-SDI recorder of your choice). Not only is the connection better, not only will you have access to true 24p recordings without pulldown, not only will you have a bigger higher-res screen, but Dave's already said that there are hardware differences that make the Samurai more powerful and capable of things that the Ninja isn't.
It can and does, but their 'clever workaround' doesn't always work -- as witnessed by its inability to properly remove pulldown from AF100 720p. Ideally they would support the timecode flag system too, and let the user choose which method they wanted to use. The timecode flag system will always 100% work on any Panasonic AG or AJ camera at least, and would be a vastly simpler process to implement than comparing fields and frames bit-by-bit. Hopefully they will get the tech specs and be able to implement it soon.I'm not 100% but I believe the Nanoflash is the only HDMI recorder the removes pulldown. And I think this is because frames aren't actually flagged in the HDMI stream and the Nanoflash uses a clever work around to do it.
Cineform avi's will drop right into both programs, it's a big part of my workflow. so yeah, another +1 for a cineform avi directshow codec over mov. Or at least the ability to choose the container
There's only one truly, really good solution (and I'm not being facetious) -- add support for both DNxHD and CineForm! :thumbsup:
