starcentral
I was excited for a moment and thought the Flame might do 2k -> 4k upscaling while recording, but that doesn't seem to be the case.
Regarding the F5, just some clarification: Even with the paid 4K upgrade on the F5 (or the F55 which has 4K internal by default) you would have to use all 4 SDI outputs to stream 4K 10-bit 422 uncompressed over SDI and the Flame I believe only has one 6G-SDI input. That means to record 4K from the F5 (or F55) you would need an SDI multiplexer to combine streams into 6G. They run $1000 or more.
You could use the 4K over HDMI but then you are limited to 8-bit 420 and I wouldn't really see the point of that.
For $999 you can install Sony's ProRes board in the F5 (or F55) that will give you many flavours of the ProRes codec, but unfortunately it's limited to HD/2K max resolution. Likely because Sony wants to push it's XAVC codec.
Still the Flame looks like an awesome monitor but sort of on the expensive side for just monitoring purposes.
cheers,
cheers,
