Bassman2003
Thanks for posting Noel. Nice images although I feel the camera is struggling with the highlights. Do you think a settings change could improve this?
Has anyone played around with the Area function on this camera? It is supposed to have a function that blurs the background but I don't see it doing it. Also I am wondering why 29.97fps is not available in AVCHD. You only get 59.97fps and 23.97fps... If a client is an interview and they want AVCHD and it is going to wind up on the web, which do you choose?
I'm not sure what you're expecting, but I don't think you necessarily understand what AREA does maybe? The AREA function lets you specify a portion of the screen that the camera should concentrate its efforts on. You can select a small section of the screen and instruct the camera to concentrate its autofocus on that small area, or to expose in that area, or to both focus and expose, or to report the brightness in that area.Has anyone played around with the Area function on this camera? It is supposed to have a function that blurs the background but I don't see it doing it.
No idea why 1080/29.97P isn't included in AVCHD, but it isn't. 24P is totally suitable for web use, and then again, so is 60p, but unless you need the high action motion rendition of 60p, I'd probably stick to 24p. Or just use the .MOV/.MP4 version of FHD 30p; granted it's more bitrate (50 megabits instead of around 21 megabits) but it'd give you the 30p you're looking for.Also I am wondering why 29.97fps is not available in AVCHD. You only get 59.97fps and 23.97fps... If a client is an interview and they want AVCHD and it is going to wind up on the web, which do you choose?
haven't had any of the new batteries(production run) to test out.....as soon as we do, I'll post it...Hey Jim, since you've now had some hands on time with it, what's the battery life like? I've read the PX270 with the same batteries isn't that great, but I've read elsewhere folks using those batteries getting extremely long run time with them.
Finally some footage I really like. Thank you, Noel. Looking clear and with nice dynamic range, not "tweaked" like so many examples before. Maybe with the DVX200 one has to be VERY careful with the settings?
The battery life is pretty similar to an AF100. I accidentally left it on without the LCD pulled out and battery use seem pretty negligible. BTW is Scene 1 likely to need color saturation boost to make it look like a GH4 in natural mode. Here is a video containing shots by both cameras. Can you tell the difference?
https://vimeo.com/142730112
Yes, the footage was GH4 and DVX200, all in UHD and yes, it was the 12-35 .f2.8 lens! It doesn't look soft to me, but thanks for pointing it out.I am in the market for a new 4K camera and I really wanted to buy this camera because I really like the GH3/GH4 look. But many of the video clips people are putting out there do not impress me.
For instance this example above. While the colors look fantastic, many of the shots in this clip look soft, sort of like a 5D Mark III that hasn't been sharpened in post. I have seen this on the GH4 if you use the 12-35mm f2.8 and stop it all the way down to F22 - it gets soft and mushy looking. Film below F8 and it looks sharp as a tack. Did you use the ND filters on these clips or just stop down the lens? Also was it filmed in 4k or HD?
Also the bokeh with this camera doesn't look too good on a lot of the outdoor "test" shots I have seen in videos. That being said, I saw some macro footage that had really nice bokeh.
I would really like to see someone with alot of skill and experience do a wedding film with this to see what its capable of before dumping $4k on the camera. Otherwise I'm considering the Ursa mini instead. While the Ursa mini doesn't have ND filters and a few other things, the footage looks great.
Am I being too picky or does anyone else notice these things too?
What you describe is diffraction limiting - it happens when the PHYSICAL dimension (*NOT* f stop) of the iris becomes small relative to the wavelength of light.I have seen this on the GH4 if you use the 12-35mm f2.8 and stop it all the way down to F22 - it gets soft and mushy looking. Film below F8 and it looks sharp as a tack.
B&H just sent me an email to inform me my camera has shipped.
- Greg
