Barry_Green
Moderator
Interestingly, those results must be better (at least as far as resolution is concerned) than you'd get with most of the 4K cameras that are currently considered high end - F5, F55, Varicam etc, as they all have 4K Bayer sensors that deBayer down to less than true 4K. That is not for one moment to say that it will therefore be a better camera as such - there's a lot more to "quality" than pure resolution - but..... it makes you think!
The reason it looks so good is because internally, as far as I can calculate, the DVX200 is a 5K camera. According to the published specifications on Panasonic's site, they claim that it uses 13.35 megapixels for 4K. I back-figured that based on the aspect ratio and came up with 5022 x 2659. Now, that's probably not the exact count, because I'm sure that the "13.35 megapixels" is rounded off, so it may be 5024 x 2660 or something like that. But it seems to me that it's using a pretty much ideal oversample ratio to deliver a fully resolved 4K; with modern debayer algorithms companies usually say that a de-bayered image retains about 75-80% of its nominal frame size as resolved detail, and at 5,024 pixels of source data, that should de-bayer down to around 3800-4020 resolved pixels of detail. Which is what the chart shows.
UHD/60P uses little oversampling, they claim 8.7 megapixels for an 8.3 megapixel frame, so you can expect that UHD/60P will resolve more around a Red One's level of resolved detail. Which still ain't nothin' to shake a stick at.
