Dan Keaton
Dear Friends,
Disclaimer: I am the Director of Sales and Marketing for Convergent Design, and the nanoFlash is one of our products.
I am one of the many people that are very excited about the AF100 / AF101 Cameras.
A few very lucky experts have had the opportunity to work with the camera. In general, it appears that they are very satisfied with the images, even though they may be improved upon before the production models are released.
Thus, recording in-camera, using AVCHD, is certainly a viable option for many.
From what I have seen, this very impressive new camera produces very nice images using AVCHD.
For some, recording in-camera will be satisfactory and I fully respect the opinions of the experts that have actually used the camera.
For others, adding a nanoFlash will greatly extend the capabilities of this wonderful camera.
I have made a list of the reasons why one may consider adding a nanoFlash.
(Obviously, I think the nanoFlash will be a great addition.)
1. By adding a nanoFlash, your images will be in 4:2:2, as opposed to 4:2:0 when recording
in-camera. 4:2:2 images provide much more Chroma detail.
This is, by far, the number one reason to add a nanoFlash to the AF100/AF101.
4:2:2 provides more chroma information than 4:2:0.
2. With the nanoFlash recording in 4:2:2, Chroma Keying (greenscreen work) will be much cleaner and easier.
Recording in 4:2:2 as opposed to 4:2:0 for Greenscreen work can be a real help in post.
3. The nanoFlash’s images will hold up much better in post, especially in serious color grading and other multi-generation post work. The nanoFlash images can hold more detail in the shadows and in the highlights.
With other cameras that have been tested at higher bit rates, the nanoFlash has improved the handling of shadow detail and highlights. This will be an unknown until the nanoFlash is actually tested with the production version of the camera.
4. The high-bit rate options of the nanoFlash provide insurance against an image with excessive detail, or a shooting situation where there is excessive motion in the image or in the camera. These are situations where a lower bit-rate codec may produce less than stellar results.
The nanoFlash records up to 280 Mbps.
5. The nanoFlash records in native Quicktime for Final Cut Pro. The files are easily edited and do not tax the processing power of one’s editing computer. Also, the workflow is “Drag and Drop” simple, and thoroughly proven.
6. The nanoFlash, via a menu option, can also record in native MXF for easy editing in Avid,
Sony Vegas, Edius, or Adobe CS5 and other NLE’s (Non-Linear Editors).
7. The nanoFlash uses the more professional CompactFlash card media. CompactFlash cards have larger capacity, and a faster transfer speed.
A professional quality CompactFlash card will always transfer faster to your NLE, than a SDHC or SDXC card. The SD cards have a 4-bit interface while the CompactFlash cards have a 16-bit interface. There are no 90 Megabyte per second read or write speed SDHC or SDXC cards.
This speed advantage can be very important when one has a tight editing deadline.
8. While advances have been made in editing AVCHD, the nanoFlashes files are easier to edit and may provide a much more pleasant post experience.
9. The nanoFlash can record in Long-GOP up to 180 Megabits per second (Mbps) or I-Frame Only up to 280 Mbps. A wide range of bit-rates are available to meet the needs of every shooting situation.
In the AF100/AF101 cameras, recordings are 21 Mbps average and 24 Mbps max.
10. The nanoFlash supports Time-Lapse Recordings.
11. The nanoFlash supports Image Flip, Image Flop, Image Flip + Image Flop.
12. The nanoFlash supports Hot Swapping of CompactFlash cards.
Thus, while recording, one can request that the nanoFlash switch to the next card,
then one can remove the other card. This allows one to continue editing while starting to edit the earlier footage.
13. Adding a nanoFlash offers Redundant Recording Capability, in-camera recording becomes the backup. It is certainly desirable to be able to record redundantly and have a backup.
In summary, a nanoFlash is a perfect accessory to improve the image quality and versatility of the Panasonic AF100/AF101 cameras.
