Barry_Green said:I would be very surprised if it worked for 24F or 30F. Sony decks don't support 24F or 30F at all, so I wouldn't expect their firewire hard disk recorder to support it either.
What about the Firestore? Does that support 24F?
Barry_Green said:Yeah, but the question is will the FireStore recognize the 24F stream? And if so, do all versions support it?
Barry_Green said:And the JVC deck will not play Canon footage at all.
There will likely never be such a deck. Canon has never built a deck, and Sony has no incentive to support a competitor's format.
But -- not necessarily. Is it specifically spelled out that it does support 24F? FCP supported 1080i HDV but didn't support 24F until 5.1.2. Sony decks all support 1080i HDV but they don't play 24F at all. It's different. It's not the same transport stream, and they would have to specifically make it compatible with 24F.Elton said:The FS-4 HD family all recognize the 1080i HDV m2t, which includes a 24F stream.
And yet Vegas 6 can capture 1080i 60i HDV, but I can't get it to capture 1080/24F HDV. The data stream is different. The hardware would need to be extended to understand the 24F data stream.It's no different than capturing raw transport streams with DVHS Cap or CapDVHS on the PC.
xray said:Editing is more -much more- than writing a stream, so FCP or Vegas needs to know what are flags and what do they mean and how to write, and so on. They need to understand the stream. A harddisk needs only to 'place' the data that is coming from the firewire. It needs to write the stream, there is the difference.
A videodeck is fundamentally different from a harddisk recorder like the FS-4. Questions for the HDrecorder are how to connect clips that passes the 2 GiG. Can you keep on recording or do you need to brake it up in 2 Gig pieces? Does it understand the record on/off button function or do you need to hard record? And can you use other containers to store the stream?
Vegas and FCP are editing programs that use intern intermediates to handle the Iframe and in-betweens. The harddisk to record the data stream is more simple.
We know that FCP can edit 25F and 24F, so I don't see a problem.
But that's just the point -- FCP had to be MODIFIED to support 25F and 24F. Straight out of the box, for the last year, Canon XLH1 users could not edit their 24F or 25F footage on FCP. It wasn't until the announcement of 5.1.2 that they finally could.xray said:We know that FCP can edit 25F and 24F, so I don't see a problem.
No, I'm *asking* whether it will or not. They make no mention of it on their website; they only spell out 1080/50i and 1080/60i.coffee said:Barry, are you saying that the Firestore Pro will NOT record 24f?
Juan Diaz said:For what it's worth, I have both an A1 and an FS-C. I haven't bought the firmware upgrade yet for the FS-C, so mine records to M2T files.
I use MPEG Streamclip to convert the files to an editing codec and, without specifying a frame rate for the converted file, I end up with a native 23.98 quicktime file. So yes the firestore does record 24f.
