billy fattey
What is the minimum bitrate? For example, shooting a blank wall?
40Mbps AVCHD High Reliability Patch:
Patches for End Users
. Wrapper
.. Native 24p/25p: unchecked
. AVCHD Compression
.. Video Bitrate FHD/SH: 41000000
.. Overall Bitrate: 43000000
. AVCHD GOP Length: unchanged
Patches for Testers
. AVCHD Compression
.. Preset bitrate: 180
.. Preset bitrate 2: 180
Thanks for putting this to the test, zigizigi. Did the camera save an MTS file when the recording failed? If so, I'd be very interested to analyze a copy of the original video file.Failed at 11:57 while shooting this cars'n'trees test scene off tripod
using this card
Kit lens, OIS and AFC on.
If you see a patch for "Limiting Bitrate" then you don't have the latest version of PTool.Conclusion: My camera doesn't like these settings or I'm missing something (which is most likely the case). I did not change anything on the Video Bitrate H or L or Limiting Bitrate. Is this part of the problem?
using this card
Tested at blank wall ... ~ 19Mbps :smile:What is the minimum bitrate? For example, shooting a blank wall?
I just bought a silicon power card and it failed most tests -worse results than my Panasonic class 6 cards
