filmguy123
So, to clarify... please tell me if I state anything here incorrectly:
The problem with a statement like "[FONT=verdana, arial, helvetica]Even the $650 Canon HV20 with its native 1920x1080 CMOS chip out-shoots the HVX200, and will certainly beat this lame has-been-out-of-the-box AG-HMC150." Is the following:
- CCDs are currently overall better than CMOS, although CMOS may have great future potential
- native 1920x1080 may yield better resolution on the HV20, however, this is countered by being forced to use greater compression to keep the data rate and recording size manageable. What this means is using long-GOP compression vs Intra-Frame, and as a result, the effective resolution in movement or in action may actually be worse than the HVX's I-Frame 1280x1080 resolution (which also uses superior CCDs). Long-GOP also makes editing more difficult and can cause problems since it is not Intra-Frame.
Further, the HMC150 will employ the superior AVC-HD codec, which is a better compression scheme than HDV that looks better at lower bitrates. This why it can shoot 13Mbps rather than 19 or 24 and STILL look better than HDV. Another advantage of this AVC-HD codec (but not necessarily the HMC150) is that this lower bit rate allows bandwidth to be "spent" on other things, such as higher resolution and better color sampling. Overall, AVC-HD will allow much higher quality HD recording due to its superior compression scheme.
[/FONT][FONT=verdana, arial, helvetica] The problem is, there have been no *GOOD* AVC-HD cameras out yet to show this. The technology in the codec is superior, but the footage captured has thus far been with cheap consumer cameras, which people compare to prosumer HDV cameras and mistakenly claim HDV to thus be superior.
[/FONT][FONT=verdana, arial, helvetica]Yet, AVC-HD it still is a long-GOP based compression, meaning that it will never out-shoot the DVCPRO-HD I-frame compression (except in still image tests or low motion footage, such as interviews). This is because any long-GOP compression scheme will suffer from motion (although long-GOP compression has improved quite a bit over time and can now deal with motion pretty well). However, it can still be problematic. However, when combing long-GOP with CMOS chips, you have additional problems that crop up in motion, strobing lights, etc. CCDs & I-Frame Compression are a better combination. Of course, with I-Frame compression, due to bandwidth limitations, you cannot currently achieve native 1920x1080 resolution, and so scaling must be used. However, scaling is an oft used and very acceptable and legitimate way to achieve HD resolution.
All this is about to change, however, thanks to AVC-Intra. The superior compression in AVC-Intra allows higher quality images to be captured at a lower bitrate, freeing up more bandwidth to be used on resolution or color sampling. AVC-Intra @ 50 Mbps is equivalent to DVCPRO-HD @ 100Mbps. This means, when you pump AVC-Intra up to 100 Mbps, you can now achieve both Intra-Frame recording *AND* native 1920x1080 resolution!
----- Is this all correct? Did I say anything wrong, and/or am I missing any important chunks here?
Thanks I finally feel like I get it!! Woohoo!
[/FONT]
[/FONT]
