Could you explain that a bit more?(...) and has film rec mode which more closely resembles film.
Ah, I always searched for "filmlook" back in the days, I should have googled "filmfeel" instead :laugh:Film Rec mode is, for lack of a better explanation, is a proprietary setting that emulates the 'feel' of film.
Right... I just wasn't 100% sure if it was like the 200 or not with those framerates.... but the varicam is still looking at over 50 framerates.The 500 has a lot more frame rates than that, it actually has around three dozen different frame rates. Every even frame rate from 2 to 60, plus odd frame rates of 3, 23, 25, and 27 fps. You just can't access them all directly from the menus, you have to program them into a scene file text file.
are those extra framerates worth another 20-30 thousand dollars and giving up 1080 recording?
Erm, the 500 shoots 1080p
But yes, ramping is one of the things that clearly sets the Varicam apart.
- Mikko
Who cares how it's recorded (as long as it's all there, as it is with pulldown with 24p), as long as it shoots progressive .. and it does.
And 1080/30p is 100% directly nativly compatible with 1080/60i. Just as 25p is with 50i in PAL/50Hz land.
- Mikko
The HPX has exactly the same thing.
