Spartacus
Hey,
were planning on recording up to 8 hours continuously to external harddrives through final cut pro.
Here are a few questions:
1) Has anyone done this before? If so please share some of your experience...
2) Will USB2.0 drives be sufficient enough for this task, performance wise (transfer
rates a.s.o.)? Would Firewire400 be better? Or do we even need FW800?
Do we need a Raid setup for the this streaming recording?
Any recommendations for good value external drives?
3) We thought about this: record to an usb drive, after shoot back up to a second drive, use one of the drives for editing (read only, render to MacPro internal Raid), after completed render put original drive in the shelve for archiving, format the second and use it next time as recording drive.
Anything wrong with that?
4) We´ll do this with two HVXs. So later we´ll have to edit this together (only hard cuts...) - how long may a DVCproHD sequence in FCP be, performance wise?
Will FCP record one continuous clip (I doubt...) if not in what intervals will FCP create clips?
Any advice greatly appreciated!
