I thought that for a while too based mostly on what was being said, but I think Sony 16 bit RAW is much cleaner now that I've used it. Not sure if apparent in these videos or not, but the F55 16 bit RAW was superior imo. I shot them all from house-left to stage-right during TEDxBoulder 2019 Spring "Within and Without." All are tighter shots made with Red 300mm Pro Prime PL. The other shooters were shooting wide. The 16 bit raw was powerful. I'll be shooting this again October 19th at Mackey Auditorium. All were in 4k-UHD but the client posted the videos in 1080p.
https://tedxboulder.com/videos
I can see why for the 8 bit timeline but if the 8 bit graphics card and 8 bit panel are factors, shouldn't I be seeing banding on the 32 bit sourced image as well for this laptop?
XAVC is basically H.264, all those extra "features" seem to me mostly marketing.
Sony's latest APS-C model A6600 advertises itself as having a 16-bit still converted to the 14-bit. One has to assume that this makes the final image closer to the 16-bit (and that's from a $1,400 camera!) than to the 14-bit.
And, while the video is only 8-bit, it looks pretty good and I wonder if a similar 10-to-8 conversion is taking place in camera.
So many are using 10-bit codecs that are being emasculated with 8-bit signal paths via their NLEs, graphics cards and 8-bit panels.
A few days ago I stumbled onto an A7RIV review (of sorts), with the talking head video shot on the same A7 RIV. Normally, it is not deemed a videocentric camera, what with the 61 MPX sensor and all (yes, it has an S35 crop). But, I thought that the colors were fine and the image was really good for the hybrid shooters.Interesting. And in that same gallery - you can see how "those awful Sony skin tones " (I'm paraphrasing others) and "horrible highlight retention" make for such a bad image. Look away - look away ...
But, I think, in the olden days, a lot of data was just tossed out before it was compressed. Now, they don't have to do that unless it's a full sensor readout with a lot of shmegapixels.I've always seen camcorders do signal processing at a higher bit depth than the final format. The DVX100 had a 12-bit. The HMC150 had 14-bit. Both recorded to 8 bit.
