Awesome! Are you considering as a replacement for your F3-type jobs?
4k 60 42 10 bit on hdmi only i think?
Very excited about the option of going PL given that I only have PL glass. EVA1 is going to be my small body for water and movi work alongside my LT so the option to share glass is very appealing. Probably my only concern is warranty. Are we saying goodbye to it by using this mount given that it appears to involve removing the existing mount from the body?
Here's the deal:
Panasonic is happy Wooden Camera is making this modification available to people. We like you to have choices. That said, if you take a screwdriver to your camera and mess something up installing this mount then that repair won't be under warranty. But if for some reason your SDI connector fails and you send in the camera with a PL mount attached we're not going to say "Hey there's a PL mount on this thing so we're not going to cover anything." Clearly one thing has nothing to do with the other. And if you send in a camera with a PL mount on it our service guys won't refuse to touch it, but they'll have to charge for the work.
Mitch to clarify,
If the sdi board is fried and the camera is modded to PL
Does one have to pay for the board or just the servicing?
Here's a radical idea... How about Panasonic service providing the install as a part/upgrade? That way the customer knows it is installed correctly, and service knows it is installed correctly. Service can also give the camera a good checkout while it is there, and service makes a quick buck. Unless Panasonic has plans of making and selling mounts, you know this would be good for both companies.
ok gotcha. so the PL Mod doesnt completely void the warranty except in the ef mount?Let's parse this one.
The SDI board (just a random example I chose here) has nothing to do with modding the lens mount, so let's take that one right off the table. It does not effect this situation in the least.
Now if the SDI board were to fail during the warranty period due to some defect from the manufacturer, then parts and labor would be covered. IBut if you hooked some jumper cables to it and plugged them into the washing machine outlet, then I'd venture to say not covered.
One has to use some common sense here, but also note that there are some specifics to various situations that must be taken into consideration.
