Its in Sp mode, I did not set it when i use it. Now i set it to MXP PF24 frame. which is better PF24 or true 24F. & in 60i or 24F?
I need it in the highest resolution for weddings, films & presentations.
I use FCPX for editings
64GB internal flash drive*
LP (5Mbps) 24 hours 30 minutes
SP (7Mbps) 19 hours 10 minutes
XP+ (12Mbps) 11 hours 30 minutes
FXP (17Mbps) 8 hours 20 minutes - Allows 1920 x 1080 Full HD Recording
MXP (24Mbps) 5 hours 55 minutes - Allows 1920 x 1080 Full HD Recording
great i will try that. as for the first video i was using xa10 built in cine mode maybe that why it look better? i will look for the sharpness mode & tune it up alittle.Yes, always use the highest quality setting on the XA10 (or any video camera for that matter). That being said, I actually preferred the footage from the first video, and according to the vimeo.com notes that is the XA10. I find the first video to have richer, more subtle color and dynamic range. Yes, if you look closely it's not quite as sharp as the second video - is that what you mean? Once you're using the highest quality setting, is there a sharpness adjustment on the XA10? I have its big brother the XF100 and find that I prefer to dial up the sharpness just a bit from the factory settings.
I don't know what you mean by "lines" but I can tell from the editing that you're using iMovie. Do you have iMovie set to retain full HD? I think by default it down samples the footage to work better on lesser power Macs, at the expense of some quality. With iMovie open, go to the iMovie Menu, choose Preferences...,go to the Video tab, and make sure Import HD video as: is set to "Full - Original Size."
As I recommended in an earlier post, you can do sharpness, color saturation, etc., adjustments with the camera - here's a thread i found that discusses this:
http://www.avsforum.com/avs-vb/showthread.php?t=1322785&page=4
